Front Caliper Type?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Metonymy, May 24, 2017.
  1. May 24, 2017 at 10:19 PM
    Metonymy
    Metonymy [OP] Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
  2. May 24, 2017 at 10:32 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Press. Wind back pistons are found on rear discs. Tacos no tienen....
    Make sure you crack open the bleeder to get that dirty fluid out of the caliper once you start pushing the piston back in.
    shakerhood, smitty99 and Metonymy[OP] like this.
  3. May 24, 2017 at 10:41 PM
    Metonymy
    None (yet)
    Perfect, and that explains why I needed to borrow this kit from AutoZone when I did the rear brakes on my Fox after converting the rear to disc from an SN-95.
    Screw it, buying the kit anyway. Will need it when I do the brakes on my gf's Infinity too.
    GPsevinSixx[QUOTED] likes this.
  4. May 24, 2017 at 10:44 PM
    GPsevinSixx
    Ros Angerus
    :thumbsup:
    FYI, large channel locks work well too. Was my go-to tool for oil filters and brake piston in my shop cart. Pad the piston with the old brake pad and put a rag on the other side to protect the caliper body and squeeze hard while cracking the bleeder screw. A little cumbersome, but you get used to it. LOL
    Never mind, just get the kit. You won't foul up the piston and seals with the kit as it will guide the piston in straight.
  5. May 24, 2017 at 10:48 PM
    Metonymy
    None (yet)
    Yeah, I have a giant Stanley wood clamp I use that has rubber padded jaws. That was my go-to for my Jeep. :)
  6. May 24, 2017 at 10:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have a large kit like that and I cannot remember but I think there was a large attachment for front calipers too, I have SN-95 Brakes on my Fox too and the rears screw in.
  7. May 24, 2017 at 10:48 PM
    GPsevinSixx
    Ros Angerus
    You get the idea!
    Metonymy[OP] and shakerhood like this.
  8. May 24, 2017 at 10:50 PM
    Metonymy
    None (yet)
    Absolutely. Really appreciate the "duh" moment for the rears being screw in. Never clicked for me before.
