Front camera mod
Discussion in '3rd Gen. Tacomas (2016+)' started by jake slatnick, Feb 19, 2017.
  1. Feb 19, 2017 at 12:33 AM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    So I'm trying to figure out a mod to run a front camera. While it would be nice to have it work "factory like" on the screen similar to the built in backup camera, I don't want to cut into factory wiring and I don't want to turn this into a major project.
    I've been doing research into wireless cameras that connect to your phone. Looks like a relatively simple and easy option. Found this online in a few minutes - https://www.amazon.com/4UCAM-Backup-Camera-iPhone-Android/dp/B00HWB91VY
    Mount it wherever on the front of the vehicle somewhat hidden and run the wires to the battery. Any time you feel like you need it while crawling or in any sketchy situation just open up the app in your phone and get the peak you need.
    That way you can always easily disassemble it in the case of selling the vehicle or no longer wanting the camera...
    I've seen there are plenty of threads on here talking about front camera options, but they all include wiring in with the OEM setup, putting in switches, etc.
    Anybody see or do anything like this?
    Any thoughts?
    Pirhett and Taco16Jessy like this.
  2. Feb 19, 2017 at 12:50 AM
    TSki
    TSki Well-Known Member
    Tyler
    Bellevue, Nebraska
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    I like the idea.. but the reviews on that camera talk about a delay between what is there and what shows up on camera. I think for your uses, crawling and the like, this thing would be a major liability. Need something that is real time.
    FirstTacoma!! likes this.
  3. Feb 19, 2017 at 12:56 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Agreed... Any advice on getting a set up that will work in real time and won't require manipulation of the factory wiring (or at least nothing permanent)?
  4. Feb 19, 2017 at 12:59 AM
    TSki
    Tyler
    Bellevue, Nebraska
    I think if you are willing to have something wired to its own display, then that could work. But it would constantly be sitting there in the way when not in use. I haven't seen too many options outside of getting into the factory wiring.
  5. Feb 19, 2017 at 1:07 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Don't really want that... Found this - https://camera-source.com/2010-toyota-tacoma-multi-camera-video-interface-for-display-radio.html
    But not being all that technical I'm confused if this will do the trick or if I'll still need to cut into anything.
  6. Feb 19, 2017 at 1:45 AM
    Taco16Jessy
    Taco16Jessy Well-Known Member
    Jessica
    Damn Corn Desert/Missing MO
    2016 BBP 4x4 AT-OR-DCSB
    Now accepting monetary donations for mods!
    How bad is the delay? If you're crawling youreally going pretty slow anyways. You'd be stopping to peak at the camera to make sure you're good to go.
    I know my canon cameras have a live view app on the phone for shooting. Do the go pros have anything like that? That way you could just mount it there when you feel like it.
  7. Feb 19, 2017 at 2:07 AM
    TSki
    Tyler
    Bellevue, Nebraska
    The go pros do.. I have used it on my dog before.. it works with the app on the iphone at least.
    FirstTacoma!! and Taco16Jessy like this.
  8. Feb 19, 2017 at 2:09 AM
    Taco16Jessy
    Jessica
    I'm a Droid Samsung user. I'll have to give it a look. I don't currently have a go pro. But this seems like a simple solution. Also can move it back up top as a dash came later on. Especially with that nifty stock mount :laughing:....
  9. Feb 19, 2017 at 9:37 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Not a bad idea. That would be really simple
  10. Feb 19, 2017 at 9:50 AM
    PCHearn
    PCHearn Well-Known Member
    Patrick
    Moore, OK
    11 PreRunner SR5
    Taco16Jessy likes this.
  11. Feb 19, 2017 at 10:13 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
  12. Feb 19, 2017 at 10:24 AM
    kdttocs
    kdttocs Well-Known Member
    Scott
    San Diego
    17 TRD O/R 4x4 DCSB
    Seems like a standard aftermarket backup cam mounted up front would work. Seems like there's plenty of places to mount front cam out of obvious view. Will always run risk of road debris damage though.
    It would require a screen mounted somewhere, maybe with semi-temporary mount for when you really don't want the screen out or take it to a custom shop and have both cams wired to a rocker switch in and unused spot on the dash. On way feeds the factory head unit with rear cam, other way on switch feeds the front cam. This would be the cleanest way and frankly pretty awesome and worth the money if really needed.
  13. Feb 19, 2017 at 10:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Most of these backup cameras transmit a mirrored image. ;) Need to find one that lets you toggle to unmirrored image. Haven't found one yet.
  14. Feb 19, 2017 at 10:52 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    This obviously sounds the most ideal... How difficult of a process is it and how much work will the shop need to do? I don't really want the whole dashboard coming off with a big wiring task. I also have no blank switches on my dash right now. Got the TRD pro, it only comes with one blank and I wired some lights to it already.
  15. Feb 19, 2017 at 11:13 AM
    Hoangde
    Hoangde Well-Known Member
    Piece of cake, if you are willing to spend $500.00 then click on HERE
  16. Feb 19, 2017 at 11:26 AM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    There are several how-to threads on getting a front camera to display on the OEM head unit. Do a search and you'll find them. Cleanest solution IMO.
  17. Feb 19, 2017 at 1:34 PM
    Taco16Jessy
    Jessica
    I like the idea for parking too. Though I don't get in the situation often that I'd need a permanent mount. I'd rather just toss it back in the glove box most days. A good mount would be the hondo garage air vent one for that.
    So does anyone know of any anyftermarket backup cameras that can un mirror themselves?
  18. Feb 19, 2017 at 6:58 PM
    kdttocs
    Scott
    San Diego
    17 TRD O/R 4x4 DCSB
    Ah you raise a good point I didn't think about. Backup cam in front would be mirrored. Not sure about that.
  19. Feb 19, 2017 at 9:52 PM
    Hoangde
  20. Feb 19, 2017 at 9:59 PM
    Taco16Jessy
    Jessica
    Can it run to an aftermarket display? I just want something small I can whip out when I need it.
