Front camera on rear view mirror screen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mhettoyota, Feb 4, 2019.
  1. Mar 28, 2019 at 11:00 AM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Ah, noted. I just drilled into the grill below my emblem, then spray painted the metal black since you could see it contrast (SR5 grill.)
  2. Mar 28, 2019 at 11:01 AM
    Kimgt
    Kimgt Well-Known Member
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    HAHA, for sure.
    BlakeyD[QUOTED] likes this.
  3. Mar 28, 2019 at 1:59 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Ok, some progress:
    1) It fits! I was able to carefully file the sides to make it sit flush in the grill, no modification to my car necessary for fitment, I do think that i'll probably need to use some glue to hold it in but its VERY snug as is.
    2) Checked Video output, its not as wide as they say it is, image output wasn't distorted and will probably be great for front view.
    XAz1vzp2xVkBlizACkgD21X7WC5OV9m1GsvI4i_-_0dba0cc96be0396f2c958863f4c778900d6098b0.jpg BJNrtlN38j38aimq_reg1_THVu2Jeq9GKvlE2tl9_ae14df80da5fff595c21386ccdbf4cc58c086c74.jpg TDHMo__GNvIhQXIAWzRl59K-0avb0zih2088IX2T_12cee429c5f501f1c3c29216e87aa482457cc840.jpg
    Bullnettles likes this.
  4. Mar 28, 2019 at 2:00 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Now all i need to do is find out how which wires i need to connect to, in order to allow the camera to feed into the rear view screen.
    and find a proper button to supply 12V to the cam.
  5. Mar 28, 2019 at 2:02 PM
    BlakeyD
    BlakeyD Well-Known Member
    Blake
    CA
    2012 Tacoma TRD Off Road "Tyra"
    Could check out CH4x4 Industries for an OEM looking switch if you have an empty spot somewhere.
    https://www.ch4x4.com/
  6. Mar 28, 2019 at 5:20 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Mine had 2 connectors in the top left corner of the fuse panel. one was a 14 pin, the other a 4 pin, the 4 pin is for the camera. I assume your 4 pin was disconnected, & the end from the camera was plugged to a new harness going to the radio, leaving the end, going up to the mirror, just hanging there, not connected to anything. I don't know if camera end or mirror end was the female.
  7. Mar 28, 2019 at 6:12 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Fitted into the grill
    jkuniverse, BlakeyD and TACOMA2NDGEN like this.
  8. Mar 28, 2019 at 6:13 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Side shot
    jkuniverse, Bullnettles and BlakeyD like this.
  9. Mar 29, 2019 at 4:51 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Just throwing this out there but you may leave some room for camera adjustments because if you are mainly using the front camera to assist in parking,IMO having the front camera not showing the edge of the front bumper is useless.
    tbird95 likes this.
  10. Mar 29, 2019 at 10:17 AM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Valid point, I'm just hoping this helps me judge parking distances so I don't hit my garage door or wall.
  11. Mar 29, 2019 at 10:24 AM
    DirtTaco
    DirtTaco Well-Known Member
    I remember seeing this same camera a while ago some one definitely has this set up somehow. I will be doing this mod in the future. The front camera will be perfect in the mountains. When cresting hill off-road it’s hsrd to see what’s directly in front of the vehicle. Good luck, looking good.
  12. Mar 29, 2019 at 3:31 PM
    BlakeyD
    Blake
    CA
    Curious to see what the picture looks like on your mirror!:playball:
  13. Mar 29, 2019 at 4:46 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    I was able to mount the cam and run half the wiring, now i need to:
    (1)attach the video wire, solder the positive (12v+) to the cam
    (2) then pull those two wire (cam 12v+ & video) into the cabin
    (3)wire up a button
    (4) most importantly: Find those darn Video signal input wires
  14. Apr 8, 2019 at 1:26 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    ok, i've made some progress with installing a push button but i'm still at a point where i dont' know what wires to tap and what to do to engage video switch over. can someone please help?
    I need help identifying the wires in question and then an instruction on how to trigger the mirror to show the video feed.
  15. Apr 8, 2019 at 1:27 PM
    #35
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    here is an actual pic to reference the back of the connector for the gentex mirror.
  16. Apr 25, 2019 at 9:40 AM
    #36
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    ok, made some progress: I decided I wanted to take an OE Style approach to making a harness for my camera instead of cutting and splicing. I did a ton of research and found that the connector housing part number and a source for the terminals, wires and crimper. here are part numbers:
    4 pin Housing: 90980-11950
    single wire with terminal: 82998-12690 (this was crazy expensive: $16 for one)
    so I sourced each component from Japan, and decided to build the harness myself with Yazaki F040 terminals.
    tbird95 and BlakeyD like this.
  17. Apr 25, 2019 at 9:40 AM
    #37
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    Next step is to connect, and see how which wires are which and see how to trigger the switch over when I need it.
  18. Apr 28, 2019 at 7:48 AM
    #38
    67siia
    67siia Well-Known Member
    J
    32164
    2009 4WD DCLB aka Chupacabra
    Following...
  19. May 27, 2020 at 7:01 AM
    #39
    RedFiveaz
    RedFiveaz Member
    2013 Tacoma Double Cab 4x4 6 Speed
    LT Front/Rear
    Whoa....where's the rest of this post?! :(
    Any updates? Did you figure this out? Forward camera in the mirror for off-roading would be amazing.
    tbird95 likes this.
  20. May 27, 2020 at 3:38 PM
    #40
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Is there a way to save the footage? A car cam is useless if it can’t be saved.
