Front camera screw from hell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Torrico, Oct 25, 2023.
  1. Oct 26, 2023 at 11:33 AM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    JIS screws are just little different at the head. I've saved many a damaged screw by trying a JIS bit instead of the regular Phillips. And Vessel makes some nice screwdrivers. It just seats "better" in the screw.
    Good luck with removal.
  2. Oct 26, 2023 at 12:04 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Japanese products don't use Phillips heads. The JIS is different enough that a Phillips screwdriver will wreck it...as you've found.
  3. Oct 26, 2023 at 1:57 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Get out the torches......
  4. Oct 26, 2023 at 2:24 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I bet holding a soldering iron to the head of the screw would do it... soften up the plastic enough to release the threads.
    Tocamo[QUOTED] likes this.
  5. Oct 26, 2023 at 4:02 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I've had success using small vice grips in those situations.
    19975lugger, Tocamo and CaptainBart45 like this.
  6. Oct 26, 2023 at 4:09 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    You want to go with the small needle nose vice grip and at latch onto the screw head like it was a bolt, 90 degrees, clamp the grip as tight as possible, make sure you have the bracket in a vice or really good grip on it.
    19975lugger likes this.
  7. Oct 26, 2023 at 4:13 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Might seem odd, but I have found that tightening the fastner then loosening it can work on stubborn threads. Having an impact drive helps but I would try to do it by hand first.
    Tocamo and mtip like this.
  8. Oct 27, 2023 at 11:34 AM
    19975lugger
    19975lugger Hand-me-down
    Southern California
    1997 5 lug LX
    Fabtech 3" spindle lift kit with add-a-leaf and shocks. Borla exhaust. K&N cold air intake. American racing wheels.
    I try to nip it from the side and use a screwdriver. Thats what I had to do for IAC valve screws.
  9. Oct 27, 2023 at 6:23 PM
    Torrico
    Torrico [OP] Member
    Daniel
    2021 Cement TRD Sport
    i got it off!
    faawrenchbndr and CaptainBart45 like this.
  10. Oct 27, 2023 at 6:26 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Final method?
  11. Oct 27, 2023 at 6:29 PM
    Torrico
    Torrico [OP] Member
    Daniel
    a plier with a concave head as opposed to a flat head, a lot less slippage!
    CaptainBart45 likes this.
  12. Oct 27, 2023 at 6:36 PM
    CaptainBart45
    Bart
    Work in progress...
    Gotter Done! I'll drink to that.
