Front Cup Holder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Mar 9, 2009.
  1. Mar 9, 2009 at 5:31 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Anyone find a travel cup big enough to fit nicely/snugly in those humongous front cup holders with the useless little size adjusters on them?
  2. Mar 9, 2009 at 5:34 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    Hmm.. I have a narrow travel mug and mine seems to hold it pretty stable.
  3. Mar 9, 2009 at 5:45 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I am referring to the two side-by-side holders right under the HVAC controls. They are worthless as anything I put in them just flops around....the smaller one right in front of the armrest is fine. The little flaps that move in-and-out to adjust to different cup sizes cannot hold any weight.....they are really a stupid design, almost like the designers just added it out of haste so the box the cupholders are in could be used for other things if you take the black spacer out.
  4. Mar 9, 2009 at 6:06 AM
    kristopherl
    Cincinnati, Ohio
    Yeah.. I will agree there has been better designs. you even shifted the whole thing to one side?
  5. Mar 9, 2009 at 6:11 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yes. If you shift the center divider it makes the holes too small. Not even sure a coke can will fit with that configuration. I did try putting cans and stuff in koozies which helped a lot. What I am looking for is some type of travel mug that is fatter that will fit without a koozie.
  6. Mar 9, 2009 at 6:36 AM
    kristopherl
    Cincinnati, Ohio
    have you looked at Target.. last time i was there they as a crap load of different kinds.
  7. Mar 9, 2009 at 8:28 AM
    sdnicker2000
    sdnicker2000 Well-Known Member
    Nebraska
    Mostly Stock 08 TRD Sport
    Rear spring TSB, Fumoto Valve, No A/C on defrost mod., tailgate theft mod.
    I use a "Bubba Keg". Narrow at the bottom to fit in the holder but it still holds 32oz. However, my Tacoma is a manual so I don't know about the auto's.
  8. Mar 9, 2009 at 8:44 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    *********NEVER DRINK AND DRIVE************
    The other day I bought a 40oz Miller Lite and it fit perfectly
  9. Mar 9, 2009 at 9:00 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Unopened of course.:eek:
  10. Mar 9, 2009 at 9:19 AM
    harshest
    Michigan
    05 PreRunner SR5
    Of course.
