Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Feb 23, 2013 at 12:04 PM
    #221
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
  2. Mar 3, 2013 at 6:54 PM
    #222
    Supertramp
    Supertramp dismember
    NC Mountains
    2009 Double Cab TRD Off-road.
    great write up!
    subbed.
  3. Mar 4, 2013 at 5:18 AM
    #223
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    great write up on fluid exchange on all diffs....
    Mine will be due this Fall.. I plan on doing myself..
    2006 Taco 4x4 TRD with locking rear diff ( dash button) LSD additive or not?
    Question?
    1. Can I use the same type/weight on all three FR Diff / Tranfer case / Rear Diff..
    2. Does it have to be synthetic ? I was planning on using Valvoline 80W-90 High Performance Gear Oil(QT) on sale at Pepboys
    3. how much will I need in Qts ?
    front-
    trans-
    rear-
    Thanks guys
  4. Mar 4, 2013 at 8:41 AM
    #224
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    i wouldnt be able to tell you with the 2nd gens but front diff and rear is the same weight. and usually you fill until it starts dripping from the fill plug, same with the transfer you fill until it starts dripping, but like i said thats with a 1st gen so hopefully a person with a 2nd gen helps you here in a bit
  5. Mar 4, 2013 at 3:13 PM
    #225
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    How much for the five gallon bucket? I could use a couple...
  6. Mar 4, 2013 at 3:30 PM
    #226
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    No additive needed.
    All the info is in the owner's manual under Chapter 8: Specifications. Go to page 398: http://www.toyota.com/t3Portal/document/om/OM35858U/xhtml/OM35858U_OM0019.html?locale=en
    75W-90 will cover the needs of all three components. 80W90 would be too thick for the front diff and T-case.
    I used a "fluid extraction" pump instead of OP's bottle cap transfer pump. It's faster but requires more care when handling:
  7. Mar 4, 2013 at 5:01 PM
    #227
    68Whiskey
    68Whiskey Well-Known Member
    Richie
    Ft.Bragg NC
    2008 4x4 DC TRD Off Road
    I really wished I could have seen this thread before... I spend this past weekend trying to do all that stuff and some info in here could have made it a lot easier
  8. Mar 5, 2013 at 5:46 AM
    #228
    Redsoxnation
    Pa.
    none yet...
    Ok check the manual link.. says to use straight 80 or 90 W in rear..
    and how is Hypoid gear oil differ from regular gear oil?
    So in closing it is safe to use 75w90 all around... or should I use single weight in the rear and 75/90 in front and transfer ?
  9. Mar 5, 2013 at 6:33 AM
    #229
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Which TRD you have? If you are 2005-2008 TRD Sport you have mechanical LSD so you have to add addtive for limited slipp.
  10. Mar 5, 2013 at 11:44 AM
    #230
    Redsoxnation
    Pa.
    none yet...
    Reg TRD chrome bumbers no scoop
    I'm going with the toyota book... 75/90 Front Diff and Transfer case
    and 80w90 in the rear diff....
    per tech sheet I added up the quarts.. Front 1.1 Transfer 1.6 rear 3.0
    So I'll be buying 3 qts of each.. Now I need to order the 6 plug gaskets and 6 denso plugs and I''ll be set for my DIY 60 k service..
    Thanks for all your help on here..
  11. Mar 5, 2013 at 2:19 PM
    #231
    KenLyns
    Belly of the Beast
    Yes it's safe to use 75W90 all around. If you tow or do a lot of burnouts :D, you can also spend a bit more and get 75W120 or 75W140 for the rear diff. The oil will be able to accommodate higher temps without breaking down.
    I buy whatever brand that stinks the least. Lucas seems pretty good. :D
  12. Mar 6, 2013 at 6:29 AM
    #232
    randyg123
    randyg123 Well-Known Member
    Randy
    2024 Bronze LTD
    Based on earlier advice in this long, long post I used Royal Purple 75W-90 in all three.
  13. Mar 6, 2013 at 9:47 AM
    #233
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Changed the transfer case and rear, the front- I got the fill plug off, the drain plug is too mangled. Gotta take it to a shop where they may weld something on to then get it off- sucks.
  14. Mar 27, 2013 at 8:04 AM
    #234
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    great write up, subd
  15. Mar 31, 2013 at 11:05 PM
    #235
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  16. Mar 31, 2013 at 11:16 PM
    #236
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Mike I just discovered that you can sub to a thread without posting in it....about 2000 posts ago :p
  17. Apr 2, 2013 at 3:14 PM
    #237
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    :rofl:
  18. Apr 4, 2013 at 6:36 PM
    #238
    boto
    boto Active Member
    Philip
    Quebec/Canada
    07 taco dbl.cab.long bed TRD
    fog anytime bhlm royal purple oil kn&n oil/air filter secondary filter removed ultimate lift kit toytech 3 inch coilovers ans add a leaf relentless fab diy bumper
    where do you get your oil pump?
  19. Apr 4, 2013 at 10:47 PM
    #239
    Monster1
    Monster1 Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    Mine is a 2012 SR5 DC V6 that came equipped with the auto LSD
  20. Apr 6, 2013 at 6:37 PM
    #240
    BryanWhiteTRD
    BryanWhiteTRD Active Member
