Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Jun 22, 2013 at 6:26 PM
    #261
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I used the same settings as dry, and I was just under the truck cleaning the frame before putting anti-rust on. Not wet or dripping from either fill or drain plugs.
  2. Jun 22, 2013 at 7:00 PM
    #262
    cleveland48
    cleveland48 Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    ok thank you I will be doing this tomorrow morning been letting em soak in pb blaster all day, maybe they will all break loose pretty easy.
  3. Jun 22, 2013 at 7:21 PM
    #263
    Agent Smith
    I sprayed PB Blaster on mine for a full week before I tried it, once per day. I used a breaker bar and kept hitting it with a rubber mallet to break them loose. The only casualty was the rear diff fill plug got three corners rounded off. Got a new one for under $7.
    Edit: I see your in Mississippi, so you should be good with your original plan. I'm in one of the worst spots of the U.S. for rust
  4. Jun 23, 2013 at 1:20 PM
    #264
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    I got my rear diff and transfer case changed but can't get the plug out of my front diff
  5. Jun 23, 2013 at 1:24 PM
    #265
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    subbed! great writeup!!!
  6. Jun 24, 2013 at 5:09 AM
    #266
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I changed my front diff and t-case. t-case wasn't too bad, but front diff was solid black. I even filled it up a tiny bit and drained it again to get some of the extra goop out.
    This was at 60k miles. The stealership said they did it at 40k. Lies.
  7. Jun 24, 2013 at 6:20 AM
    #267
    Taco Guy11
    Joe
    Western Maryland
    The stealer ship is supposed to do mine today when they do my free oil change today hopefully they do it ill know they I couldn't get the plug out if my front diff I plan on trying to break it lose after they change it to make sure they did it but I did get the t case an rear done.
  8. Jun 24, 2013 at 9:02 AM
    #268
    Taco Guy11
    Joe
    Western Maryland
    They charged me 49$ to do it with my fluid. They stripped the plus and got it out some how an put a new one in
  9. Jun 24, 2013 at 9:45 AM
    #269
    Agent Smith
    im assuming its the fill plug? If it is take it out and antiseize that bitch before it locks on again.
  10. Jun 24, 2013 at 10:21 AM
    #270
    Taco Guy11
    Joe
    Western Maryland
    No it was the drain plug on the front
  11. Jun 29, 2013 at 9:30 AM
    #271
    cleveland48
    Andrew
    2012 TRD Off Road
    I just finished both diffs and the transfer case. Was not bad at all I'm at 27,000 miles so figured I would do it now. All the plugs broke loose easily, front diff drain plug was definetly the tightest though. Put all synthetic in might just be in my head but it does seem to drive smoother. And it also seems smoother shifting into 4WD. If I can just talk myself into changing spark plugs I'll save some money!
  12. Jun 30, 2013 at 6:31 PM
    #272
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    That front diff was a pain. I couldn't get them out with a 1/2" socket wrench, had to get out the 3/4" and use an adaptor for the 1/2" allen socket. Even then I had a hard time.
    I imagine they torque them tight because they can (since it's a steel case)? I don't think it's necessary to torque them that tight. I didn't use a torque wrench to put them back in, but I didn't put a lot of load on them and no leaks.
  13. Jul 7, 2013 at 8:53 PM
    #273
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    So if the front diff, rear diff and t-case are all the same size bolt can I replace all of them with the hex bolt pictured? And just to confirm is the hex bolt part #90341-18021? Also will these fit the transmission ? I plan to replace all of the drain and fill bolts because they're extremely rusted, look like crap and I fully expect to screw a few of them up in the process.
  14. Jul 18, 2013 at 10:37 PM
    #274
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Stryker420 likes this.
  15. Jul 19, 2013 at 5:57 AM
    #275
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  16. Jul 19, 2013 at 8:52 AM
    #276
    JLink
    Josh
    Ocean, NJ
    I didn't think it was too bad.. Last time I picked up a Toyota one I paid about the same and its not magnetic
  17. Jul 19, 2013 at 10:41 AM
    #277
    george3
    New Jersey
    Magnetic is nice. Let us know how much it picks up next time you change it. Mine is stock so it would be interesting to know. Thanks. Curious George
  18. Jul 22, 2013 at 11:08 AM
    #278
    JLink
    Josh
    Ocean, NJ
    It'll be a while before I order one. I just changed my diff fluid 10k miles ago and I change it every 30k. Unless I lock the front, re gear, or break something it'll be a year till I do it again.
    But if I do order one ill share my experience
  19. Jul 22, 2013 at 12:49 PM
    #279
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Is the thread the same for a 1st gen's front, transfer and rear diff? If so I'll get three of those mag plugs, not just for the mag but it would be nice to do away with the hex- my front is done, totally done for.
  20. Jul 22, 2013 at 12:58 PM
    #280
    george3
    New Jersey
    Thanks.
