Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Jul 27, 2013 at 5:19 AM
    #281
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
  2. Jul 27, 2013 at 6:24 AM
    #282
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
  3. Aug 4, 2013 at 6:15 AM
    #283
    Redsoxnation
    Redsoxnation Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    I did the fluid change this past weekend.. basically I did most of my 60k service myself..
    all differentials and transfer case, spark plugs, serpentine belt, front pads..
    Thanks to Chris4x4 and Jspadaro for posting DIY pictures.. I saved $ 340 in dealer costs..
    the thing I won't tackle is the auto trans fluid change...
    Question? dealer is telling the WTF fluid doesn't required change until 100k.. My Taco is a 2006 4x4 TRD with on 60k on it now..it has a towing package but I really don't tow heavy ..about 6 times a yeat I hook up jon boat trailer 1100 lbs ..
    but maintenance book calls out for a auto trans fluid change at 60 k with heavy tow .. I 'm going on 8 years should I have this done????
    Any feed back as always would be nice..
    Thanks
  4. Aug 4, 2013 at 11:47 AM
    #284
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Anything on this? Please save me going in there and swapping them all around to prove this lol.
  5. Aug 5, 2013 at 8:56 AM
    #285
    randyg123
    randyg123 Well-Known Member
    Randy
    2024 Bronze LTD
    WTF or ATF? The ATF can be changed but I think the WTF is left alone. :D
    I forget the cutoff mileage but my dealer said they would not flush the tranny after a certain mileage if no flush previously done. They have said this on all of my Toyotas. The mileage cutoff was somewhere between 50-75k. Their reasoning was that if the mileage was higher, there was a statistically greater chance of some solids accumulation fouling the system (e.g. make a valve stick). So I wouldn't wait.
  6. Aug 6, 2013 at 4:36 AM
    #286
    Redsoxnation
    Pa.
    none yet...
    Ok thanks... I meant to say WS .. I type WTF because the dealer called it World Transmission Fluid.... but WTF applies to DIY... Thanks
  7. Aug 9, 2013 at 8:20 PM
    #287
    joer189
    joer189 New Member
    Joe
    Colorado
    2006 Tacoma V6 TRD off road
    Front approach plate. TRD air filter.
    so I bought the same gear lube featured in the tutorial (Mobil 1 synthetic 75W-90) for my 2006 Tacoma TRD off road, double cab). Is the chirp a common issue since I cant get redline locally and shipping will likely be pricey. Lower down in thread someone stated that GL5 could damage sync rings??
    Another thread cautioned against going synthetic in the rear diff to avoid ruining the seals??
    Hate to put in something that is going to cause problems.
    Thanks in advance all!:)
  8. Aug 10, 2013 at 5:40 AM
    #288
    Redsoxnation
    Pa.
    none yet...
    I used Valvoline (dino) GL-5 80-90w in the rear and Valvoline 75-90 front and Tarnsfer case no issues yet..
  9. Aug 11, 2013 at 10:36 AM
    #289
    Nostunknivek
    Nostunknivek Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    Started my rear diff/ front diff/ transfer case yesterday. Just assumed I had a 24mm socket in my socket set. Unfortunately I did not so I went and picked one up. I also assumed I had a 10mm hex socket as well in my massive bit set I have. So i didnt think to buy one while at crappy tire while I was there. So I just left the front diff for today. Gotta go get the hex socket and wait for the ground to dry (it rained like crazy here last night, finally!). All in all easy peasy. Glad I could keep the money out of the stealerships hands. Thanks for the writeup!
  10. Sep 22, 2013 at 5:12 AM
    #290
    Eternal24k
    Eternal24k Well-Known Member
    Vermont
    2009 SR5 V6 4x4
    did the trans, transfer, and both diffs this weekend thanks to these threads.
    Hardest part was pumping the oil, my pump left 1/4 quart in the bottle, made it really hard to accurately measure when it was in a place i couldnt use a funnel (transfer and transmission).
  11. Sep 24, 2013 at 11:03 PM
    #291
    ChunkyLover53
    ChunkyLover53 Well-Known Member
    California
    2013 Regular Cab 4x4
    I tried looking up the recommended maintenance at each service interval but basically came up with no good info. Does anyone have a link that shows what's recommended every service interval?
  12. Sep 24, 2013 at 11:24 PM
    #292
    andjenliang
    andjenliang Well-Known Member
    Andew
    LBC/OC/LAX
    10 DCSB PreRunner V6 TRD Off Road
    Stock
    Here you are buddy.
  13. Sep 25, 2013 at 6:17 AM
    #293
    Nostunknivek
    Kevin
    Victoria, BC
    I tried getting my front diff plug out but I stripped the 10 mm hex bolt. What can I do to break it free? Just heat it up with a torch and grab it with some vice grips? Give it a couple smacks with a ball peen hammer to break the rust free? The rear diff an the transfer case were a breeze. Just ran into some problems with the front. Why don't they just put a normal drain plug in there?
  14. Sep 25, 2013 at 8:45 AM
    #294
    Eternal24k
    Vermont
    2009 SR5 V6 4x4
    front is a pain, not sure how you could grab it with vice grips, and given the torque i doubt you would be able to remove it if you could grab it.
    I am sure someone else can chime in, but i cant think of much other than welding the hex into it and then removing it.
    After doing mine i wished i had replaced the hex bolts with new ones, i definitely will next time as my truck is getting rustier (Vermont...)
  15. Sep 25, 2013 at 12:04 PM
    #295
    Agent Smith
    I'm just south of you, I put anti-seize compound on the threads for next time, then sprayed HD anti rust over the bolts to keep them from rusting further.
  16. Sep 25, 2013 at 12:30 PM
    #296
    Eternal24k
    Vermont
    2009 SR5 V6 4x4
    I also did some anti seize, i like the idea of spraying the outside down, I think i might just apply a thick layer of wheel bearing grease
  17. Nov 22, 2013 at 7:22 AM
    #297
    spinso71
    spinso71 Active Member
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    OME MT64
    Thanks for the write up. Very helpful. I did mine this weekend and picked up new crush washers using the part numbers you gave. I wanted to add, for those like me that don't know, crush washers are directional with the cupped end towards the bolt flange. I made sure before starting that I had them on correctly.
  18. Dec 22, 2013 at 8:26 AM
    #298
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Not sure if this has been asked already or not but I know my 2012 doesn't have mechanical LSD so it doesn't need the additive. My question is if the Mobil1 synthetic I bought says it has additives for Limited Slip, can I still use it in my non-mechanical LSD? I can't find Mobil1 anywhere that doesn't say limited slip on it is the problem. Seems like almost all the synthetic gear oil has additives in it. Will it hurt a non-LSD differential?
  19. Dec 22, 2013 at 9:58 AM
    #299
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    It won't hurt it, you're just paying a little extra.
  20. Dec 22, 2013 at 10:01 AM
    #300
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Drain and refill, done.
    Basic 80w90, good to go.
