Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Mar 16, 2014 at 12:21 PM
    #341
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Being from Maine, your bolts are likely as rusted on as mine here in Mass. Spray em with PB blaster everyday for a week before you attempt, I still ended up needing to buy two fill bolts after kind of rounding those bitches off.
  2. Mar 16, 2014 at 12:33 PM
    #342
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
  3. Mar 16, 2014 at 3:51 PM
    #343
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    That's good advice! I will do that for sure. Thanks!
  4. Mar 18, 2014 at 6:41 PM
    #344
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    I just did this tonight along with the rear diff. I am the second owner and at 105k miles (bought it at 70k). The previous owner didn't think any of the diffs had been changed. The rear diff and transfer case oils were relatively clean looking and the bolts came off pretty easily. The rear plug magnet did have some gunk on it though. I had to soak the front diff drain plug in penetrating lube for a bit and then go at it HARD with a breaker bar and finally got it to break free. I'm glad I did because it was black as tar and the magnet on the plug was loaded. Which leads me to believe the rear and x-fer case had been changed but the front hadn't.
    The hand pump was a real bitch though. I feel like I only got 25ml of oil in with each pump, so basically 40 pumps for a liter which seemed to take forever. But I did just buy a $5 pump.
    Also, I bought 6 quarts of mobil 1 75-90 and I felt like I didn't really have enough to allow all of them to overflow (probably because the pump couldn't quite grab all the oil). I'm going to go back and get another quart tomorrow and pump it until all the cases overflow for peace of mind.
    All in, I'm glad I did this and it was very easy with this walk-thru and the rear diff linked in the OP. I drove it down the road a bit and 4wd seemed to engage quicker than before. Might just be placebo effect but it feels nice knowing clean oil is in there, esp after seeing that front diff and thinking about how much I used 4wd this winter...
  5. Mar 19, 2014 at 6:54 AM
    #345
    txusa03
    txusa03 Well-Known Member
    I have a 4x2 reg cab with 70K miles. Are the front diff and transfer case only applied to 4x4 and that my car don't have these and I don't have to change out the oil?
    TIA
  6. Mar 19, 2014 at 7:17 AM
    #346
    jlleiber
    Justin
    Indiana
    Correct. No 4x4 means no front diff and no transfer case.
  7. Mar 25, 2014 at 6:13 PM
    #347
    BRUIN8124
    Mark
    DONE! SO EASY! I can't believe how much people pay to have this done. Thanks for all the help!
  8. Mar 27, 2014 at 3:58 PM
    #348
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Is Redline MT-90 the prerfered gear oil for 2nd Gen?
    I know it was ideal in my 04 Tacoma.
  9. Mar 31, 2014 at 7:16 AM
    #349
    BCephus
    BCephus Alright then
    Slingblade
    Virginia
    08 DCabSB 6 speed OME'd
    OME 886/dakar heavy, ARB bumper, 9.5XP warn, PDM tranquil kit, custom bullet hole tailgate anti theft kit, Camburg ball joint UCAs, Centerforce II clutch, FJ cruiser TRD wheels (black) with 285/75/16 Ds (white letters out, (Duh))
    No. The MT is for manual transmission, and it's a GL-4 oil. Keeps the synchronizers happy. I just changed all the gear oil in mine and put amsoil gear oil in my transmission. It shifted like crap. When I changed it to the amsoil MT oil, all was great again. Cost me 30 bucks or so to learn that.
    There are better choices for diff gear oil, namely your favorite GL-5 in the weight in the owners manual. A lot of the oils already have a LSD additive, which will not hurt anything if you don't have a limited slip differential.
  10. Apr 3, 2014 at 3:43 PM
    #350
    TacoOwner?
    TacoOwner? Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    Thanks for the information, made the changing of diff very helpful!
  11. Apr 4, 2014 at 10:17 AM
    #351
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Hey gang,
    I know from reading this thread that 80w90 is ok, but just thought i'd make mention that one of the Toyota Dealer's here in Austin told me over the phone on 2nd Gen Tacoma's they're using 80w90 in the front diff, transfer case, & rear diff. Also told me getting the 80w90 with the LSD additive is ok to add to the front and rear but is really only required for the rear. Again, just wanted to share info on what the dealer locally told me they're using.
    I'm in a 2011 SR5 4x4 with the tow package in case you're wondering.
  12. Apr 4, 2014 at 12:00 PM
    #352
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Is it okay to use 80W-90 weight? Every place I go to has only that weight.
  13. Apr 4, 2014 at 1:21 PM
    #353
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    75w90 and 80w90 are both acceptable.
  14. Apr 4, 2014 at 1:30 PM
    #354
    jlleiber
    Justin
    Indiana
  15. Apr 4, 2014 at 1:42 PM
    #355
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    I'm new, so i'm sure a more senior member can speak more to this, but its fine to use either one. The argument usually surrounding synthetic vs./or regular "dino" oil is that you don't have to change the synthetic oil as often as your manual requires (30k, 60k, 90k etc).
    I'm running synthetic but will still change every 30,000. Synthetic or not for my peace of mind i'll follow Toyota's specs.
  16. Apr 4, 2014 at 3:29 PM
    #356
    Agent Smith
  17. Apr 6, 2014 at 8:17 PM
    #357
    jsi
    jsi Well-Known Member
    native earthling
    I just did the front and rear diff, the transfer case and greased the drive shaft U joints and learned a couple of lessons.
    1. Do not buy the harbor freight oil pump if you buy the 1 quart oil bottles. No, just don't buy it period. It's too big to fit in the quart bottles and the extension that comes with it won't reach to the bottom of most 1 gallon jugs.
    2. Loosen the fill plug but leave it in place when you remove the drain plug. This slows the initial flood of oil which allows you to adjust the drain pan if you don't have it positioned just right.
    3. Air tools make short work of removing the fill plug. Don't use them to remove the drain plug. With my air gun even the shortest pull of the trigger unscrews it all the way.
    4. You don't need an oil pump for the rear diff if you lower the spare tire.
    5. Lower the spare tire and check the air pressure. Mine was 15 pounds low.
    6. You don't need an oil pump for the transfer case.
    7. You need an oil pump for the front diff.
    8. If you made the mistake of buying the Harbor Freight pump cut the top off the oil bottle so it will fit inside.
    9. Greasing the rear drive shaft U joints is dead simple because the zerk fittings are on the outside of the joint.
    10. Greasing the front U joints is a bit harder because the zerk is in the center off the joint.
    11. Saving hundreds of dollars in labor is fun!
    ready6delta and QChawks like this.
  18. Apr 6, 2014 at 11:00 PM
    #358
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    All good points. I never pay for this - does it really cost "hundreds of dollars in labor" ? That'll buy a whole lot of beer - my usual pay myself for the job:D
  19. Apr 7, 2014 at 9:33 AM
    #359
    Fabulous
    Fabian
    Calgary, AB
    I did all three this weekend along with changing the spark plugs, and an oil change. Would have cost about $800 at the local lealership to have all this done. Front diff was a bit of a pain to get at, but no biggie.
  20. Apr 9, 2014 at 5:27 PM
    #360
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Thanks for the write up! Just did all 3 along with the tranny. I used a pump for the tranny but the front diff I just used a hose on the end of the angled tip of the mobil one bottles. worked great. I would have used the pump but didnt want to mix tranny and diff fluid or take the time to clean the pump. Advanced auto sells a red/black pump for 14$ that works great. The pump i had for the lower unit on the boat didnt fit the toyota atf WS bottles so I just got a pump with a hose instead of a fitted pump.
