Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Apr 10, 2014 at 7:47 AM
    #361
    jliberatore92
    jliberatore92 Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    So I have roughly 1.1 qts of redline mt-90 left over from doing the tranny. I want to do the front diff and have heard it takes more than 1.1 qts to do. If I don't have enough redline, can I add in some mobil 1 75w90?
    (I had to order the redline online and have some left over mobil 1 from the rear diff)
  2. Apr 13, 2014 at 6:37 PM
    #362
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Thanks for the write up, did mine this weekend while recoating the frame. I used Mobil1 75w90 synthetic. The transfer case oil wasn't bad at all, looked unused for the most part, but the front diff was murky black at 33k miles. I had the truck completely up on jacks and level... Transfer case took exactly 1.1 qt, front diff took exactly 1.5 qt.
    I also took care of all 5 zerks on the drive shafts, just put it in neutral and the rear drive shaft turns easily ( at least with the rear wheels off). $800 for this service is ridiculous...
    Heres a tip.. Getting to the front diff openings is a little easier if you take off the front drivers side wheel. And always always always open the fill ports first before the drain!
  3. Apr 16, 2014 at 8:08 PM
    #363
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    Technically it holds 1.6 so if you were slightly off level or didn't fully drain, then it would. But you want to go until it leaks back out the fill hole anyways
  4. Apr 18, 2014 at 3:42 PM
    #364
    Rtres09
    Rtres09 Well-Known Member
    San Antonio
    06 Black DCLB 4x4
    So do I need to add the lsd additive to the front diff also? Like i do for the rear diff?
  5. Apr 18, 2014 at 4:04 PM
    #365
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    No
  6. Apr 19, 2014 at 3:15 PM
    #366
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Just changed both diffs and the tcase at 30k.
    Both diffs were very dark and the drain plugs had a thick gooey sludge on them but the tcase fluid was as clean as the new stuff I put in.
    Probably a waste on the tcase but I suppose it's good for peace of mind anyway.
  7. May 2, 2014 at 5:18 PM
    #367
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    I just changed my front the other day and noticed once in a while turning left it almost sounds like either tyres or something's binding so e what nothing I feel in the wheel..so jot sure whAt it is any ideas ?
  8. May 3, 2014 at 6:20 AM
    #368
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Wheel bearing?
  9. May 3, 2014 at 4:08 PM
    #369
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    I've never changed the gear oil on my 2010 trd 4x4 off road, currently 57k. I'm going to do this before 60k.
    the only place I can do this is on my driveway, which is not level. is it better for rear of the truck to be higher? I change engine oil in my driveway and keep the front on the higher side since the oil drain hole is towards the rear. not sure if this is the best position for differential oil change. I want the fill hole to be on the higher side right? I can see the fill hole for rear and transfer case facing the rear, so I should make the front of the truck on the lower side of the driveway so I don't underfill? or it should not really matter?
    I think my truck has auto lsd, so I do not need lsd additive right? I plan on using mobil 1 75w90 like op
    thanks
  10. May 3, 2014 at 4:20 PM
    #370
    lyodbraun
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    That's what I was thinking as well, the noise I use to hear that sounded like the wheel bearing roaring at low speeds has gone away since changing the diff... So I'm not to sure gonna have to jack it up and see if any play on the wheels?
  11. Jun 4, 2014 at 8:29 PM
    #371
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    Ok last night at work I changed my the oil in the rear end and put 3quarts back in it then I look and about half a quart did not go in checked and could not touch any oil with my finger so I put what's equalivent to ro tell at in was just over half a quart in is that going to hurt or do I need to change it pretty fast
  12. Jun 5, 2014 at 7:32 AM
    #372
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    So i dont need an additive in my rear diff on a 2012 Sport? Correct?
  13. Jun 5, 2014 at 7:38 AM
    #373
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    no, for a sport I think you DO need the additive in the rear. you don't for the front. There's a lot of diff oils out there that have the LSD additive already in it. Mobil 1 synthetic 75-90 for instance has LSD additive.
  14. Jun 5, 2014 at 11:34 AM
    #374
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Don't all newer trucks(minus TRD Offroad) have LSD that uses the brakes not mechanical LSD..meaning..you don't need the additive unless you have an older model.(forgot if it was 05+ use brakes instead of mechanic or not.)
  15. Jun 5, 2014 at 8:07 PM
    #375
    bjboucher
    Brad
    San Antonio, Texas
    The mechanical LSD that required the additive was done away with several years ago. I think 2008 or 2009 was the last year for it.
  16. Jun 5, 2014 at 9:19 PM
    #376
    Shauncho
    Shaun
    Parts Unknown...
    none
    Is it bad to use an oil that has the additive?
  17. Jun 6, 2014 at 9:27 AM
    #377
    bjboucher
    Brad
    San Antonio, Texas
    Not from what I've read. It's ok to use it when not needed but if you need it and don't use it you'll have issues.
  18. Jun 6, 2014 at 10:07 AM
    #378
    Shauncho
    Shaun
    Parts Unknown...
    none
    that's kinda what I figured. Good to know :thumbsup:
  19. Jun 8, 2014 at 12:17 PM
    #379
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Just got done changing my front axle gear oil for the third time and have a little issue. lol After pumping in the new oil and tightening everything up, cleaning up and I pulled the drain pan out and uh oh.
    Looked into the pan and I could see the copper washer that BELONGS on the drain plug laying at the bottom. :eek: I'm not draining the axle to put it back on. lol Is this going to be a problem ?
    Thanks
  20. Jun 8, 2014 at 3:11 PM
    #380
    bjboucher
    Brad
    San Antonio, Texas
    Just keep an eye on it, see if it's leaking. If it's not leaking I imagine you're just fine.
