Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Jun 8, 2014 at 5:12 PM
    #381
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    If you are going to attempt this with a full All Pro Offroad skid plate package have some drip pans ready.
    Rear Diff - no problems.
    Transfer case - remove fill plug, remove drain plug (you should always do this order just in case you cant get the fill plug off after you have drained the oil). Drain the oil right onto the skid plate. It will flow through the drain holes in the skid. And its probably going to drip for a week.
    Front diff - remove fill plug. Use a siphon pump to remove as much oil as possible. Remove drain plug and allow it to drain onto the skid plate. (I got nearly everything with the siphon pump so only 100ml or so came out onto the skid.
    By not removing the skid plates I easily did this job in two hours. If I had to remove and replace them I would probably be still at it since I would have pressure washed them and stuff.
  2. Jun 8, 2014 at 6:12 PM
    #382
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Thanks BJ, kind of what I was thinking also. Just got back from a little spin in it and going to leave it sit over night on concrete. I'll find out in the morning, lol.
    My conscious will probably get me though. I may clean the drain pan with brake parts cleaner along with a funnel that has a long tube and do it again. I'll just reinstall the washer then pour the fluid from the pan right into the funnel and button it all up again. :D
    Sucks getting older, I should have caught the washer wasn't on the plug when I removed it.
  3. Jun 18, 2014 at 8:34 AM
    #383
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    just changed differential oil on front, rear and transfer case for the first time on my truck at 57k. I was expecting the front oil to be clean, but it came out the darkest. The rear actually came out the cleanest, almost like new oil, and I rarely use 4wd. I know the dealer told me to use 4wd at least 10miles each month (for oil to flow and lubricate the parts), which I did on the first year only. I'll probably have to do it more often. It's just annoying when making turns on 4wd, probably need to find a 10 mi stretch of road to do this once a month.
  4. Jun 18, 2014 at 8:41 AM
    #384
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    I was the exact same way. Front came out black and rear was clean. I changed mine after a long winter of lots of 4x4 driving
  5. Jun 18, 2014 at 9:06 AM
    #385
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Front was probably so dirty because of the Front differential bearing issue.
  6. Jun 19, 2014 at 2:28 PM
    #386
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  7. Jun 21, 2014 at 9:42 PM
    #387
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    also, my truck was left in the garage for a full week. I did not drive the truck or even start the engine before I started the gear oil change, and I was able to put in 3.5 qts in the rear differential before the oil started to flow out of the fill hole.
  8. Jul 3, 2014 at 5:08 AM
    #388
    josephfed
    josephfed Member
    I have a 2005 Tacoma. Do I have to add the additive when changing the Diff and Transfer case oil?
  9. Jul 3, 2014 at 10:09 AM
    #389
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    What model Tacoma? I think only the TRD Sports had the mechanical LSD back then. Does your differential have an LSD sticker on it? You can always put the additive in, won't hurt it if it doesn't need it but if you need it and don't have it you'll have issues.
  10. Jul 3, 2014 at 10:23 AM
    #390
    josephfed
    josephfed Member
    Thanks. I'll look for the sticker.
  11. Jul 3, 2014 at 10:49 AM
    #391
    bjboucher
    Brad
    San Antonio, Texas
    Forgot to mention, I believe it's only the rear differential that needs it, not the front or transfer case.
  12. Jul 6, 2014 at 11:13 AM
    #392
    jackbower6864
    jackbower6864 Member
  13. Jul 6, 2014 at 11:17 AM
    #393
    bobswanson
    bobswanson Tacoma247
    Bob
    Chickamauga
    96 Tacoma 2.7 & 2009 Tacoma TRD OR
    Interior - Pioneer NEX-4000, Kenwood Digital Amps, JL Audio Door speakers, JL Audio Stealth Sub box. Exterior - Bilstein 5100's, TRD Intake, TRD Exhaust, ATO Rear Bumper
    Nice write up. Sub'd
  14. Jul 8, 2014 at 12:26 PM
    #394
    jackbower6864
  15. Jul 14, 2014 at 2:54 PM
    #395
    Red Demon
    Red Demon Well-Known Member
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Tinted windows Upgrade to New 2014 radio Weather Tech Front Lift:2.5 ICON Extended Travel Coilover Shocks Icon Uni Ball Tubular UCA Rear Lift: Icon 1.5" AAL ICON 2.0 Aluminum Series Rear Shock Relentless Front Bumper Relentless Rear Bumper SOS Sliders and skid plate
  16. Jul 19, 2014 at 11:26 AM
    #396
    thewood87
    thewood87 New Member
    Great writeup. I appreciate the help!
  17. Jul 19, 2014 at 3:16 PM
    #397
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
  18. Jul 25, 2014 at 9:02 AM
    #398
    Yota64
    Yota64 Professional Threadjacker
    SUB'D. Just what I need. I have a question. I am at 100,xxx miles and the maintenance on this truck has been poor, I am redoing everything. Aside from transfer case oil and hand pump, is there anything else I need to buy? filter/additive? Thanks
  19. Jul 25, 2014 at 11:13 AM
    #399
    jlleiber
    Justin
    Indiana
    If your profile is up to date and you have a prerunner that hasn't been converted to 4x4 then you wouldn't have a transfer case or front diff. Just the rear diff. For that you could buy some new crush washers for the drain/fill plugs. I would just call the dealer up and they should find them for you. If you lower the spare out of the way, you won't need a hand pump for the rear diff.
    I changed all my fluids in my 4x4 at close to the same mileage and reused all the washers without a problem.
  20. Jul 25, 2014 at 11:49 AM
    #400
    Yota64
    I knew that 2WD only had a rear diff, but I didn't know that they didn't have a transfer case. So that just leaves engine oil change, transmission fluid change, and differential fluid change? Are there any other fluids that I need to do?
