Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Jun 29, 2015 at 10:35 AM
    #561
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
  2. Jul 1, 2015 at 9:42 AM
    #562
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Great post / sticky thread. Thanks.
    Did mine today. Truck is 3 years old (2012) with 40,000 mi, never had a diff fluid change before. As far as experience goes, I've only ever changed the RR diff oil in my old '94 Toyota truck. Still, I wasn't expecting a huge problem, maybe only some hard to remove bolts.
    I bought the diff oil in a 1 gal jug and 1 extra quart bottle and got a transfer pump that screws on to the 1 gal jug. After I finished the diff changes I dumped the remaining oil out of the 1 gal jug and put in the T-case and transmission oil so I could use the same pump for them. The 1 gal jug + pump makes a nice stable platform to pump from, and with a long hose from the pump to the fill hole you just set the jug on the ground and press down on the pump. Easy.
    Transfer pump was $6.00 and was sold in the same area of the store as the fluids. Despite other people saying their cheap pumps broke immediately, this one worked fine and seems solid.
    I ended up having no trouble with any of the fill or drain bolts except a little bit of swearing and rubber mallet hammering was required on the front diff drain plug. All others came out easy. I did need an extension to get to the fill bolt on the transmission as the driveshaft is in the way, but otherwise, just a 24mm socket, a ratchet, and a 10mm allen on a socket adapter, a one gallon oil jug with the side cut out (drain pan), and some rags was all I needed.
    I used non synthetic fluids and even deviated slightly from the manual's recommendations mainly due to availability. Instead of the spec'd 75W-85 GL-5 I used 80W-90 GL-5. I did use the correct 75W-90 GL-5 for the T-case and manual transmission as those are easily available. I think I should be okay.... :)
    Both my diff's fluids were gross. My RR had some water in it from creek crossings and such, and was black but also had streaks of milky color in it. Drain plug had some fur on it and a few small slivers of metal. FT was black as hell despite me only using 4WD maybe 500 miles a year, and the drain plug had a ton of fur on it, maybe about the size of 1/2 of the last knuckle of my pinky finger. More than I've ever seen on a drain plug before.
    My T-case fluid looked clean and my tranny fluid was about what I expected, not awful but still dirty.
    I flipped upside down but reused all the crush washers.
    I did not have to drop my skid plate to get to the front diff (SR5 truck).
    In order of easiest to hardest to access, it was RR diff, T-case, transmission, FT diff. Took about 90 minutes to do.
    My tip, after completing the job, hit all the drain areas and fill areas with aerosol brake cleaner, to degrease the surfaces. That way it's very easy to see if there is a leak after you are done.
    Also, some guys are asking about skipping certain areas, like I saw some people asking about not changing the FT diff oil as they rarely use 4WD - I would not advise this. My FT diff was the worst of all. If I was to skip on one thing it would be the T-case, as that fluid looked great; but it's super easy to do that one and it's only 1.1 quarts so you're spending like $6 on it. Just do them all.
  3. Jul 1, 2015 at 10:30 AM
    #563
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Do you have your diff breather relocated?
    If not, my understanding is the water likely came in through your axle seals which may now be bad.
  4. Jul 1, 2015 at 12:42 PM
    #564
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    No, I do not, but I'm confident that the seals are fine. No leaks evident. I'm not concerned.
  5. Jul 1, 2015 at 7:49 PM
    #565
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    How frustrating. I wanted to do the front diff and transfer case today, went out to buy that hand pump; NOBODY CARRIES IT! I've tried NAPA, Part Source, and Canadian Tire. What gives? The guy at NAPA didn't even know what I was talking about at first until I showed him. He looked through the catalog, nothing. I even crawled under to see if I could manage a 1qt bottle in there to fill, for the transfer case sure, but the front diff I would be screwed.
  6. Jul 2, 2015 at 11:08 AM
    #566
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I found a pump at Auto Zone, if you have one of those around.
  7. Jul 2, 2015 at 11:10 AM
    #567
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Walmart carries them in their marine oils area.
  8. Jul 2, 2015 at 11:10 AM
    #568
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    (which is by the regular oil area)
  9. Jul 2, 2015 at 7:31 PM
    #569
    Silence9
    Alberta, Canada
    That's an idea also, I still wouldn't mind finding a pump for future changes too. Thanks for looking for me bud. :)
    Not that I know of, might be an American thing.
    That would be awesome, I'll check tomorrow after work!
  10. Jul 3, 2015 at 4:19 AM
    #570
    hetkind
    Howard
    Johnson City
    Post 569 has a link to a bucket pump from Northern Tool.
  11. Jul 3, 2015 at 9:10 PM
    #571
    Silence9
    Alberta, Canada
    Looks like I'm going to have to buy it online. Walmart didn't have them either!
  12. Jul 4, 2015 at 6:46 AM
    #572
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Dang, I'm surprised. I've bought a couple of them from Walmart. Always in the marine area by the oil section.
  13. Jul 4, 2015 at 8:01 PM
    #573
    Silence9
    Alberta, Canada
    I just did mine today. No need to pre-soak the plugs, no need for the pump, no need to take skid plate off. I got frustrated trying 4 different stores and not having the pump so I did it without it. Front diff: Fill plug came out with 2 taps of a hammer on the ratchet. The drain plug took 5 good swings then cracked loose. As long as the hex is deep in the spot, and square on, it won't strip. Push the ratchet forward to eliminate bounce back, ensure it's always square, and whack it with a hammer. Xfer case, easy, it's a huge socket, just some muscle is all you need. Easy job, magnet was really fuzzy and goopy. Glad it's got brand new stuff in there.
    MQQSE likes this.
  14. Jul 5, 2015 at 5:07 AM
    #574
    hetkind
    Howard
    Johnson City
    Yes, the long, flex head ratchet is very handy, and is great for drain plugs...There has been one of those in my took box for over 20 years.
  15. Jul 5, 2015 at 10:41 AM
    #575
    Silence9
    Alberta, Canada
    I have one, a Stanley 1/2" drive breaker bar that pivots. Problem is, Canadian Tire only had 3/8ths 10mm hex sockets.
  16. Jul 5, 2015 at 12:57 PM
    #576
    hetkind
    Howard
    Johnson City
    Www.mcmaster.com and they sell single sockets, get the impact style, Williams brand.
    DoorDing likes this.
  17. Jul 18, 2015 at 10:38 AM
    #577
    blazer69
    blazer69 Well-Known Member
    I have the same tool but a 3/8 drive and was trying to remove the front diff drain plug and couldn't get it off. Even after using some bolt lube first. I haven't tried hitting it with a hammer yet though. and the rear diff came off no problem.
  18. Jul 19, 2015 at 4:04 PM
    #578
    53rdcard
    53rdcard Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    This i am sure has been covered, but after reading 30 pages i didnt see anyone mention it. Do you need to replace the washers on the rear differential drain and fill plugs? and do any of the others have those?
    A couple of how to's i found indicated that they are crush washers so i wanted to check before i take it apart, and find that putting it back together without it leaking will require those parts.
  19. Jul 19, 2015 at 4:15 PM
    #579
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Yes, they are crush washers. Some owners have been able to get away with not replacing them. Some haven't.
    Yep, comes with a magnet, too: http://goldplug.com/shop/ap24/
  20. Jul 19, 2015 at 4:22 PM
    #580
    53rdcard
    Excellent thanks, ill get replacements before I do it then
