Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Aug 13, 2015 at 3:43 PM
    #601
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    that works too.
  2. Aug 23, 2015 at 7:20 AM
    #602
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Good Morning all,
    Quick Question I just changed the transfer case oil on a 2014 TRD Off Road and it seem to take a little more than the 1.1 qts listed so I stopped when the oil came out the fill hole and put the plug back in that should be good right?
  3. Aug 23, 2015 at 8:28 AM
    #603
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Yes.
  4. Aug 23, 2015 at 9:33 AM
    #604
    IPNPULZ
    going to be fun!
    Thanks MQQSE,
    I drove around the block and then opened it up again then topped it off with about 2-3 1/2 oz's more all looks good.....
  5. Aug 23, 2015 at 10:26 AM
    #605
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :thumbsup: and your Xfercase thanks you. ;)
  6. Aug 24, 2015 at 9:57 AM
    #606
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Can you damage anything if you overfill your Transfer Case or Front Diff?
  7. Aug 24, 2015 at 3:28 PM
    #607
    IPNPULZ
    going to be fun!
    I don't see how you can overfill it since it will pour out the top hole and run all over the place?
    Stryker420 likes this.
  8. Aug 24, 2015 at 3:53 PM
    #608
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Well, since where I did the fluid exchange isn't a level surface, I felt the need to put more 75W-90 in the Transfer Case than the recommended amount of 1.1 Quarts.
    And to answer your question, it's easy, you fill the gap where the pump hose isn't occupying the fill hole with your thumb & pump more 75W-90 in. When you remove the pump hose, slide your thumb over the fill hole to hold in the gear oil so it doesn't leak out. Finally, place the fill plug close to your thumb and do the el swaparoo.
    So my question stands, if I put more than the recommended amount in, could it have a negative impact?
  9. Aug 24, 2015 at 4:14 PM
    #609
    IPNPULZ
    going to be fun!
    Well, I just changed mine this weekend and it took a little more than the 1.1 qts I drained and refilled then drove around the block going in and out of 4WD a couple of times came back opened it up and added about 2-3 oz's more till t ran out the fill hole.
  10. Aug 24, 2015 at 4:14 PM
    #610
    Taco Salad Sport
    Taco Salad Sport Well-Known Member
    Castle Rock, CO
    2012 Sport DCSB 4x4
    Nah, you should be fine. Unless you were pointed downhill in one of those San Francisco streets I wouldn't worry about it. Other trucks used to have seals fail between the transmission and transfer case. Oil would push it's way through the seals on the ground, as the entire transfer case would be full! Even so, all the mechanical components were fine and the seal would need replaced ($$$$$$$$).
  11. Aug 24, 2015 at 4:26 PM
    #611
    IPNPULZ
    going to be fun!
    I just figured I put in about 1.2-1.3 in and I think I will be fine as it is a little more than then factory fill....
    JackAttack likes this.
  12. Aug 24, 2015 at 4:29 PM
    #612
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes...absolutely. It depends on how much excess you have in there. You can build up too much pressure & heat in the diff and can blow out the axle seals. Granted, that's probably an extreme case ....
    The diff has a 'breather plug' that release pressure - but that doesn't dissipate heat. If the breather plug is clogged (with normal amounts of oil) , can also blow axle seals.
  13. Aug 24, 2015 at 4:37 PM
    #613
    IPNPULZ
    going to be fun!
    So .1 of a quart would be how exactly how much 3.2 oz = 35.2 oz?
  14. Aug 24, 2015 at 4:42 PM
    #614
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    .09464 liters o_O
  15. Aug 26, 2015 at 11:15 AM
    #615
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Well, the one I overfilled was the Transfer Case. Maybe when I do the Front Diff, I'll let some of the 75W-90 out of the Transfer Case.
  16. Aug 26, 2015 at 11:35 AM
    #616
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I have an 06 sport with the limited slip rear end. I changed that last weekend. I put the Valvoline+limited slip additive gear oil into the rear diff.
    Do I need to put the same in the front diff and trans case?
    If I did (I have not done the front yet) put that oil in there would it cause a problem?
  17. Aug 26, 2015 at 12:57 PM
    #617
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Completed the front diff oil change today; months after I did my rear and transfer case. Saved the best for last since I need to remove my heavy skid plate! Front diff oil was dark. Transfer case oil was still golden, and rear diff was milky-possible water contamination.
  18. Aug 26, 2015 at 1:33 PM
    #618
    Taco Salad Sport
    Castle Rock, CO
    2012 Sport DCSB 4x4
    No, only the LSD in your rear. (PS, this has been asked like 100x)
  19. Aug 26, 2015 at 1:33 PM
    #619
    Manwithoutaplan
    ID
    Good little thread i will sub.
  20. Aug 26, 2015 at 2:18 PM
    #620
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Thanks you, and I didn't really want to read through 33 pages. I hit the first few looking then just decided to ask.
