Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Oct 2, 2015 at 8:42 AM
    #661
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    so, it looks like you used all the same fluid for the Tcase and diffs. I got 4.56s installed from ECGS and they use 85w-140 gear oil. I still use that for my diffs today. Does anyone know if its safe to use that for the Tcase, or what fluid is appropriate, strictly for the Tcase? I don't have a manual handy, I appreciate some insight :thumbsup:
  2. Oct 2, 2015 at 9:00 AM
    #662
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I an sure someone that has regeared already will chime in soon but from what I could dig up with a quick search most just used the thicker in the front and rear and left the T case alone. Also, just a quick note to change the fluid after a 500 mile break in or so.
  3. Oct 2, 2015 at 10:03 AM
    #663
    Skootter14
    Jeremy
    swapped both diff fluid after the 500 mile break in, thanks for the help!
    Ill stand by on the Tcase fluid recommendation. I appreciate it
  4. Oct 5, 2015 at 5:32 AM
    #664
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Transfer case is also 75w90. Even in your manual, under the fluid specs.
  5. Oct 5, 2015 at 6:52 PM
    #665
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Redline MT-90 is what a lot of people run in their t-cases and I am going to soon too :thumbsup:
  6. Oct 7, 2015 at 7:40 AM
    #666
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    Hello everyone,
    2012 TRD off road auto with 33k. Manual said to change front, rear diff and transfer case if you are towing with ur truck. Never towed anything thing but a lot of people recommending to change it anyway so I think I will go ahead and do it, peace of mind. What type do you recommend? Does the rear diff locker require special oil?
    Thanks
    I apologize if my questions were already answered above, it's pretty long thread and did not go trough it all.
    Ain't no body got time for that :D
  7. Oct 7, 2015 at 8:12 AM
    #667
    TACO TX
    Kelly
    Denison ,Texas
    Nothing special required for locker, 75-90 is great for all three. Mobil 1 75-90LS is very popular. I would definitely go synthetic whatever brand I chose. :cheers:
  8. Oct 7, 2015 at 8:40 AM
    #668
    Nalex
    Thanks a lot.
    I changed them at the dealer for my Lexus GX470 last week. They used 75w90 synthetic as well for $300 they also changed the plugs. They advised me not to flush the transmission. Planning to do it myself on the tacoma. I thought it is complicated and requires special tools. Thanks to this forum it is actually a fairly easy procedure.
  9. Oct 21, 2015 at 2:59 PM
    #669
    LSUTaco
    LSUTaco Well-Known Member
    Jax
    11 DC TRD sport
    You're not an idiot, and if you are then i'm right there with you. Thanks for asking my question for me. :cheers:
  10. Oct 21, 2015 at 5:36 PM
    #670
    thegardentool
    thegardentool Active Member
    2013 Tacoma TX Baja Barcelona Red
    I replaced all 3 today with Mobil 1 75W90LS. It was my first time doing it. It did take me close to 3.5 hours start to finish, but I didn't have anything very well organized and took a break between each stage. I also had a hell of a time with front differential drain plug getting it off, and the transfer case skid plate took me a while to MacGyver enough adapters together because I didn't have a 3/8" 10mm deep socket for the front two bolts. Looking back I probably could have just used an extender to get it without resorting to a deeper socket. I'm confident the next time I do it, it will take a lot less time.
  11. Oct 22, 2015 at 3:53 PM
    #671
    atrain20210
    atrain20210 Active Member
    Aaron
    Vermont
    07 Tacoma TRD Off-Road
    Oil catch can, DIY aux input, 7 Pin trailer plug relocate
    So I did this last weekend, great write up by the way, and had some difficulty getting the front diff drain plug off. I actually ended up shearing off a bolt on the skid which I will try to back out possibly this weekend. But my question is that when I was having trouble I went to my Dads shop, he works for a trucking company, and they had a mechanic there. I told him that I will begin doing this every 30,000 miles, he said he would do it every 100,000 because gear oil will change viscosity and some other crap, but basically its like if you never change your transmission fluid you probably shouldn't start past 150,000 miles or so. He says seen lots of transfer cases and diffs ruined by doing this. I bought my truck with about 105k and just turned 150k without ever doing this service.
    So I was want some of ya'll to weigh in on that.
  12. Oct 22, 2015 at 3:56 PM
    #672
    atrain20210
    Aaron
    Vermont
  13. Oct 22, 2015 at 4:44 PM
    #673
    TACO TX
    Kelly
    Denison ,Texas
    I drained and filled my transmission twice at 160,00 as well as diffs and t-case. Shifts better, rolls easier. If you have problems from these, you had problems already and the same goes for leaks.
  14. Oct 24, 2015 at 8:11 PM
    #674
    Stiffy62
    Stiffy62 From the Frame up.
    Southern Indiana
    09 Tacoma,Access Cab,Base(not any more)
    You been here to long, When there's TOO MUCH TO LIST!
    My .2c, I did a partial trans fluid change with filter at 35000,(this is not really a filter it is a screen) I also switched the diffs and transfer case to Mobil 1 75/90 full synthetic (I use mobil 1 in my crankcase)....I just had the dealer flush the tranny completely 78000 mi ($200.00)...I can't feel my truck shift anymore while driving "normally" In rain today the shift from 2nd to 3rd broke the tires loose consistantly, (engaging the traction control) this is NOT a bad thing. I will change the diff and transfer again this comming weekend, How offten I change them after that will be based on what condition the fluids are in when I drain them.....I guess the point Im trying to make is, All vehicles are subject to different conditions and varrience in build. Err on the side of caution, Take time to look at your fluids, and over change them at first, Then learn what your machine is telling you, Consider the conditions you use it in, The fluids will tell tale!!
    FWIW
    Flhighby likes this.
  15. Oct 24, 2015 at 11:53 PM
    #675
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
  16. Nov 1, 2015 at 10:26 AM
    #676
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    I just did all three of the fluid changes. The front diff was definitely the worst and had the most metal shavings, oil was very "milky and dark" vs the rear and transfer being just slightly darker than new oil. I could see changing the front if it is the same color after 15k miles but the rear and transfer case seem they could go a lot longer between intervals.
  17. Nov 1, 2015 at 1:27 PM
    #677
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    If you use Mobil 1 do you still need to add LSD additives or not? If I remember reading somewhere in the thread that if you have sports edition you need to add 4oz of LSD.
  18. Nov 1, 2015 at 1:45 PM
    #678
    TACO TX
    Kelly
    Denison ,Texas
    2009 and later are all auto LSD. No additive needed.
    patbegley and madsand[QUOTED] like this.
  19. Nov 1, 2015 at 1:51 PM
    #679
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    Thanks guys! I just reach 30k and I'm gathering the stuff I need and do this maintenance.
  20. Nov 8, 2015 at 1:29 PM
    #680
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Just did these at 2k (I know I know) and that front diff drain bolt is really a bugger even on a relatively new truck. Add years to that and that is why there are so many problems with them. Front and rear diff fluid was on the darker side with a bunch of sludge on the plugs, transfer case oil looked like it just came out of the bottle.
    Thanks for the write up! It was very helpful.
