Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Jun 24, 2016 at 12:37 PM
    #821
    max2
    max2 Well-Known Member
    Gary
    Ruidoso, NM
    Yes Lucas 75W90 is great for both diffs and the transfer case.
    For your transmission do not use Lucas 75W90. Transmission fluid will depend on if it's auto or manual.
  2. Jun 24, 2016 at 12:40 PM
    #822
    DirtyTeRD
    DirtyTeRD Well-Known Member
    Steven
    Ohio
    Black 07 TRD
    BlackMAXX Tonneau, Toytec 3in 5100s with eibach coils, Toytec BOSS leafs, LR UCAs, Relentless fab diamondplate tailgate cover, lowes slimline toolbox, pelfreybilt bed bar
    Thanks guys. I was just looking for diffs and xfer case to start. I will need atf for the trans. I wish it was manual though.
  3. Jul 16, 2016 at 6:13 PM
    #823
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I just did all 3 of mine today and found the same thing... front and rear were a little gray, with just a bit of fine metal on the magnets. The transfer case oil was clean as new. Used full synthetic 75W-90. Truck is just a little quieter, it seems.
  4. Jul 31, 2016 at 8:37 AM
    #824
    Jake.A
    Jake.A Well-Known Member
    California
    2014 Tacoma TRD Sport
    Quick question...would it be bad if i fill diffs and t case till fluid started coming out of fill plug?
  5. Jul 31, 2016 at 8:59 AM
    #825
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    That's what I did. The fill plugs aren't at the very top of the diffs, so I don't think you could over fill it.
    Jake.A[QUOTED] likes this.
  6. Jul 31, 2016 at 9:00 AM
    #826
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    I just did both diffs and transfer case last week. I did a ton of research and reading and watching YouTube, and from EVERY video and article "how to's" I read/watched, they said fill until the oil just starts to ooze out of the fill hole. I did that, and compared the specs on the capacities with filling until it starts to "ooze" out of the fill hole, and it was really close to the capacity amount in the owners manual, give or take maybe a tablespoon of oil as it oozed out. So long story even longer, yes fill until the oil just starts to leak out of the fill hole. Remember also, not every drop will be drained out, so you prob will not be able to pump the exact amount the owners manual specifies due to some old oil remaining. Hope this helped and didn't confuse you more. I suggest also when filling the rear diff, fill until it starts to ooze, then just thread the plug back on finger tight then go do something else for 10 min or so (I drank a beer) then remove the plug and fill some more. This allows for the gear oil to to run into the axle and distribute evenly
  7. Jul 31, 2016 at 9:29 AM
    #827
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Um... I'm positive if you read the directions on the first page, that is what it tells you to do.
    Stryker420 likes this.
  8. Jul 31, 2016 at 9:33 AM
    #828
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Um...just giving my take on what I did. Just tryin to help guys out that may not have read up on everything
    Jake.A likes this.
  9. Jul 31, 2016 at 9:53 AM
    #829
    Jake.A
    California
    It also states specific quantities for filling..then at the bottom of post says to fill until it drains out fill plug..hence my question..only trying to see what others did so I can get an idea of what I'd like to do. But thanks captain obvious
  10. Jul 31, 2016 at 9:54 AM
    #830
    Jake.A
    California
    Thanks bud
  11. Jul 31, 2016 at 9:57 AM
    #831
    Jake.A
    California
    Yea I've read mixed things as well..some with specific specs and others just say fill till fill plug starts draining some out..just wanted to get an idea of what people do on here..And good to know about letting it sit for a while...thanks!
  12. Jul 31, 2016 at 10:03 AM
    #832
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    You bet. It really is a pretty simple job too. As with anything, just take your time. I do recommend if not the night before, at least a good while before you start, to hit the plugs with some penetrating spray because they can be stubborn knuckle busters, and be sure to pick up all new washers, each plug takes a different one, I got mine from the dealer, only like $10 bucks for all of them. Just a good thing to replace each time you change the oil, some guys are gonna chime in and say you don't need to, I just figured for as little as they cost it's just good peace of mind. I have the part numbers for each if you need them. 2 are aluminum, 3 are crush style and 1 is a copper washer.
  13. Jul 31, 2016 at 10:47 AM
    #833
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Jake.A, here ya go
    2013 DCSB TRD OR 4x4 4.0 V6 (should be the same for your 2014)
    Torque ft lbs:
    Front diff drain plug washer (copper) = part #90430-24003 48 ft lbs
    Front diff fill plug washer (crush style) = part #12157-10010 29 ft lbs
    Transfer case fill plug (aluminum) = part #90430-18008 27 ft lbs
    Transfer case drain plug (aluminum) = part #90430-18008 27 ft lbs
    Rear diff drain plug (crush style) = part #12157-10010 36 ft lbs
    Rear diff fill plug (crush style) = part #12157-10010 36 ft lbs
    *post edited for rear diff fill and drain plug torque specs
  14. Jul 31, 2016 at 8:14 PM
    #834
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    You can call me Senior Chief Obvious.
  15. Aug 2, 2016 at 3:44 AM
    #835
    DrFunker
    DrFunker Well-Known Member
    Which rear diff plug measurement is correct?
    Is it 49 ft/lbs ?? or
    36 ft/lbs ??
    :notsure:
    Another post
    http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep4.htm#tranny
    I am going to say 36 foot pounds.
  16. Aug 2, 2016 at 7:53 AM
    #836
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    I apologize in advance if this is a stupid question.
    I changed the front diff fluid last week but did not realize i had to change the transfer case also because I was referencing a different thread and not this one. That other thread did not mention anything about the transfer case. So if I change the transfer case fluid this week, would I need only 1.1 qt or are the front diff and transfer case "connected" and so if I drain the transfer case, the front diff fluid (1.6 qt) will also be drained, making the total fluid that I would need be 3 qts?
    Gawd, that does sound like a stupid question. My hunch is that they are not "connected" and that I would only need 1.1 qt for the transfer case but I just want to make sure.
  17. Aug 2, 2016 at 8:30 AM
    #837
    Jake.A
    California
    Yea the t case takes its own fluid. The front diff and t case are not connected so if you drain the t case you will not drain the front diff. And yea you will just need 1.1qts to fill it...maybe a little more to get the fluid to start creeping out of fill plug. Hope this helps
    deeznutz[QUOTED] likes this.
  18. Aug 2, 2016 at 9:15 AM
    #838
    deeznutz
    Seattle, WA
    09 SR5 DC LB 4x4
    Thank you!
  19. Aug 2, 2016 at 11:28 AM
    #839
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Norton and DrFunker[QUOTED] like this.
  20. Aug 2, 2016 at 2:34 PM
    #840
    DrFunker
    Whew.
    Thanks for clarifying. Was hoping I didn't eff up.
    :cheers:
