Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Dec 8, 2016 at 2:39 AM
    #921
    DrFunker
    DrFunker Well-Known Member
    :woot:
  2. Dec 9, 2016 at 11:38 AM
    #922
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
  3. Dec 17, 2016 at 10:03 PM
    #923
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Thanks for the write up. came in handy today. only 5k miles but had to change out the needle bearing. that was some dark gear oil. magnet was pretty dirty too. may try the transfer case soon.
  4. Dec 29, 2016 at 5:08 AM
    #924
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Good Morning...I found the listings for the crush washers on the first page or two...and that is nice. However, when I did my 90k service on my '11 AC 4x4 manual, 4.0, both the fill and drain plug on the front diff were unhappy...had to tap in the allen wrench, then beat if off the wrench with a 2# ball peen, wire brushed, soaked it in the parts tank and such before reinstalling, but they need to be replaced.
    Does anyone have the part numbers to the drain and fill plug on the front diff handy so I can online order and avoid making a trip to town?
    The numbers I found for the crush washers are:
    12157-10010 Rear diff, both, front diff, top
    90430-A0003 T-Case, top and bottom
    90430-24003, front diff, bottom, brass,
    and I need Front Diff drain and fill plug part numbers please...
    I buy my gear lube by spec in the five gallon bucket, and use a hand pump with a long hose and curve nozzle, and normally go through a bucket a year, depending on the work I am doing, sometimes, a couple buckets a weekend if a bunch of us have been through deep water or if we are maintaining a fleet of motorcycles for yearly change out of vital fluids. Current bucket, from Amazon, Castrol Heavy Duty Gear Lube, API GL-5, 80W-90. I collect the old pails and use them around the shop, there must be 10 different brands represented. I am quite partial to the Valvoline and Castrol brands. The NAPA house brand is Valvoline, last time I checked.
    This is a very helpful thread...I did the entire truck with a 10mm allen, long, socket mount, 3/8" and a 24mm chrome short socket on a 18" flexhead 1/2" ratchet. The allen is Armstrong brand, and I got this set from McMaster-Carr, and the 24mm socket was a cheaper from Northern Tool, the impact in the same size in Williams, now a Snap-on Brand. Ratchets were both Craftsman, neither one is newer than 20 years.
    Howard
  5. Dec 29, 2016 at 4:36 PM
    #925
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I don't know how to link a thread, but these guys will be able to help you.
    This is the thread name
    Camelback Toyota Discount for TW Members!!!!
  6. Jan 13, 2017 at 6:30 PM
    #926
    Gabezz
    Gabezz Well-Known Member
    Gabe
    Los Angeles, CA (Montebello)
    '12 Tacoma TRD Off-Road DCSB
    Volant CAI w/Ram Air Scoop, Volant Throttle Body Spacer, Flowmaster SS Dual Exhaust, JBA Cat4ward Headers, Body Armor Side Steps, ProComp 3in Suspension w/Pro Runner UCA's and shocks, Various KC Hilites LEDs.
    Job complete. Thanks for all the input, recommendations and such, saved me approx $130 in labor for a few hours of my own time, now I know how to do it next time.
  7. Jan 14, 2017 at 2:26 AM
    #927
    DrFunker
  8. Feb 6, 2017 at 2:33 PM
    #928
    Hman945
    Hman945 Member
    Elmer, NJ
    09 Sport
    Greatly appreciate the how to instructions for replacing the gear oil in the fron and rear differential. I plan on tackling this job over the weekend but before I do I would appreciate if someone can clear a few things up for me. I have a 2009 Tacoma Sport Dbl Cab and intend to use Mobil 1 75W-90 LS gear oil in the rear. I'm confused as to whether or not I'm suppose to use the limited slip additive (CRC Equa-Torgue) with the Mobil 1. I called two different dealers and I was given two different answers. Any clarification? Thanks
  9. Feb 6, 2017 at 5:56 PM
    #929
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    I thought 09 doesn't have mechanical limited slip. Afaik only 05 - 08 Sport had mechanical limited slip diff where addictive was required and any other combination/trim of Tacoma does not need it.
  10. Feb 7, 2017 at 1:04 AM
    #930
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
  11. Feb 7, 2017 at 3:54 AM
    #931
    Hman945
    Hman945 Member
    Elmer, NJ
    09 Sport
    Thanks...ordered all the gear oil and crush washers to do the job. I'm very concerned that I waited so long (95,000 miles) to do this job and here I thought I took good care of my truck. Until reading this post I had no idea this should of been done at 30K. Hope this lack of service hasn't done any harm. Thanks again for everyone's info.
  12. Feb 7, 2017 at 4:15 AM
    #932
    DrFunker
    Welcome to TW. :laugh: Know what you mean.
    You should be okay. Did mine for the first time at 60k.
  13. Feb 14, 2017 at 8:21 PM
    #933
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Went through quite a few posts and didn't see an answer. One quart for transfer be sufficient? Do i need to worry about the .1?
  14. Feb 15, 2017 at 1:09 AM
    #934
    robssol
    Rob
    S. Wisconsin
    Fill it until it's full. (coming out the fill port) Or 1.1 quarts (35oz) whichever comes first.
  15. Feb 15, 2017 at 6:14 AM
    #935
    kjkroll83
    kjkroll83 Well-Known Member
  16. Feb 15, 2017 at 2:17 PM
    #936
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    my 11 takes LSD additive.
  17. Feb 15, 2017 at 9:41 PM
    #937
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  18. Feb 17, 2017 at 2:39 PM
    #938
    Hman945
    Hman945 Member
    Elmer, NJ
    09 Sport
    Okay now I'm back to being confused again...Asuchemist has a 2011 and says his tacoma requires the lsd additive. Curious if he has the decal on the rear differential 'cause mine does not. Should I just add the lsd additive and forget about it? Plan on doing this oil change this weekend. Thanks for any suggestions that will clear this issue up.
  19. Feb 17, 2017 at 4:28 PM
    #939
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    In my opinion, you don't need the additive. I doubt it would harm anything if you decide you do.
  20. Feb 17, 2017 at 4:47 PM
    #940
    Hman945
    Hman945 Member
    Elmer, NJ
    09 Sport
    Thanks...going without it.
