Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. May 3, 2012 at 12:42 PM
    #141
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    My pump is good for quart and gallon bottles. Got it at O'Reilly.
    Check there, Harbor Freight, Advanced Auto, NAPA if you have any of those in your area.
  2. May 3, 2012 at 12:44 PM
    #142
    boshak
    AG
    CA
    BTW, usually if the store carries quart gear oil, they'll have a quart pump. Odd that you haven't found one.
  3. May 3, 2012 at 5:55 PM
    #143
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    agreed. strange it only fits gallons. i'll just order one off Amazon. i'm sure i can find something else to get me free shipping on the order.
  4. May 3, 2012 at 7:13 PM
    #144
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    I just stuck the hose from the "gallon pump" down into the quart bottle.... worked fine for me.
    Jesse
  5. May 3, 2012 at 7:36 PM
    #145
    boshak
    AG
    CA
    Ive tried that before but the gallon hose was too thick for the quart neck. Thats why I got the dual pump.
  6. May 13, 2012 at 6:16 AM
    #146
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
  7. May 28, 2012 at 5:43 PM
    #147
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Subscribed.
  8. Jun 9, 2012 at 7:28 PM
    #148
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    I was finally able to get started on this project today. I changed the spark plugs as well as the rear diff and the xfer case. Naturally, I kept getting interrupted so the front diff will have to wait till tomorrow.
    I used Royal Purple (had no idea the stuff was actually purple:rolleyes:) Anyway, I was able to fill the xfer case without using a pump since the bottle had a long tapered neck.
    I guess there's no danger of overfilling? I wasn't sure how to measure 1.1 quarts so I just filled until it started running out, then waited a bit, and filled again till it started running out.
  9. Jun 9, 2012 at 8:59 PM
    #149
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    I think as long as you waited a bit you are good.
  10. Jun 9, 2012 at 10:34 PM
    #150
    CJH9980
    Clint
    2018 TRD PRO
    That's what I was thinking. If it is off, it's not off by much. I'm sure there's an allowable margin of error
  11. Jun 28, 2012 at 4:19 PM
    #151
    Silver Streak
    Silver Streak Well-Known Member
    Westin Bull Bar
    Good write up. Changed mine and rear diff it about 1 and a half hours. put valvoline conventional gl-5 in mine
  12. Jul 2, 2012 at 5:26 AM
    #152
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    changed mine yesterday using this now that i finally had the right pump. went pretty smoothly taking exactly 2.7 qts total between the two. The front diff shot oil further than expected and i had a mess to clean up. Nothing a little kitty litter and 45 shop towels couldn't handle. thanks for the write up!
  13. Jul 11, 2012 at 2:31 PM
    #153
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    So there is a right pump and a wrong pump. Enlighten me. Thanks.
  14. Jul 11, 2012 at 5:47 PM
    #154
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The right pump is whatever works for you to put oil in there. :D
    Yeah as long as you fill even with the fill hole you're good, even if it settles and you can add a little more after it's fine.
  15. Jul 12, 2012 at 2:08 PM
    #155
    george3
    New Jersey
    Thanks for the reply.
  16. Jul 28, 2012 at 6:37 AM
    #156
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
    So I have read the whole post. I have 2012 V6 4x4 SR5. All I can find locally is Mobile 1 75w-90 LS. My understanding from the post is I can put 75w-90 in both diffs and the transfer case. I do not have a LS. There was one post that said I could the LS oil in all three. Then there was one that looked like it said to only use it in the rear.
    Is it OK to run LS version of the oil in all 3 without hurting anything? How long have you been doing this? What exactly does LS do?
  17. Jul 28, 2012 at 6:45 AM
    #157
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah it'll be fine.
  18. Aug 22, 2012 at 4:03 PM
    #158
    troy28
    Need help
    So I went to the Stealership today to get the crush washers for a 2012 DCLB for the Front and Rear Diff and Transfer case. I told them what I was doing and needed all the crush washers.
    This is what they gave me:
    2 x 12157-10010 (Front and Rear diffs)
    1 x 90430-18008 (Transfer Case)
    I asked them wasn't I supposed to have 6 crush washers and isn't one of them supposed to be brass?
    He looked back in the computer and said no that is all you need.....Based on the above post I quoted it would appear the dealership is completely wrong.
    Can any one confirm what I need for a 2012 DCLB?
  19. Aug 22, 2012 at 4:10 PM
    #159
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd . . . :popcorn:
  20. Aug 22, 2012 at 5:24 PM
    #160
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Sounds like he gave you crush washers for only the drain plugs.
    In reality you can re-use all of the old ones if they appear to be undamaged and you clean all the surfaces well.
