Front diff breather wont stop leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by loggerpete, Apr 24, 2010.
  1. Apr 24, 2010 at 3:51 PM
    loggerpete
    loggerpete [OP] Member
    Oil is proper viscosity,proper level,and oil keeps coming up front breather hose even if I don`t drive it for couple days.Nobody including dealership knows why this is.I emptied the diff filled it up to proper level I even blew down breather to see if air flow was restricted and next morning oil on the ground from breather.:confused:
  2. Apr 24, 2010 at 9:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Found this, maybe it will be helpful. :notsure:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/20222-oil-leaking-front-diff-breather.html
  3. Apr 25, 2010 at 7:07 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    if your front vent is puking, you've overfilled the diff.
    i'm not sure exactly how much you're supposed to use. ...but i know if you fill it to the point where it's coming out of the fill hole, you've used too much.
    you'll find that most dealerships will also overfill it as well. .....seems everyone thinks you're supposed to fill it until it starts coming out of the fill hole ...and that's not how it works for all applications.
  4. Apr 25, 2010 at 8:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This might be a normal occurance, atleast it was for the 1st gens and the old 96 I used to own. Mine did the same thing and I never over-fill my stuff.
    I did research it (this was years ago) and from what I've seen, the overall design of the diff doesn't breathe (air pockets) and causes the oil to go up the breather tube.
    I ended up putting an extended breather on the front - a hose that went up as far as the clutch master cylinder. That way...I'd never lose any oil.
    When it leaks like that...eventually, you're gonna be low on oil.
    Do some research on google or other forums.
  5. Apr 25, 2010 at 5:50 PM
    loggerpete
    Yeah I`m gonna extend line to as high as clutch and put fuel filter on it.Another guy here did this and says it works.
    He says oil goes in filter about 1/4 inch and eventually drains back down.
    I`ve changed all my diff oil the proper way and all the sudden it starts doin this.
    385,000kms still goin though and only went through four CV`s
  6. Apr 25, 2010 at 5:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Hmm, wierd. Mine has never done this.
