Front diff drain plug alternate OEM part
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jowett, Apr 16, 2019.
  1. Jul 8, 2019 at 10:24 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Thanks OP.
    Just ordered one to keep as a spare to use the next time I booger up the drain plug. I've had to chisel off two of them so far.
    mcharfauros likes this.
  2. Jul 8, 2019 at 11:00 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Not sure, I think just the drain plug. No one seems to have any trouble with the fill plug so I am still using the stock one.
    mcharfauros and Benny123[QUOTED] like this.
  3. Jul 9, 2019 at 5:14 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Me too Daniel!!! I need this now!
    08TRDOFFROAD[QUOTED] likes this.
  4. Jul 10, 2019 at 1:46 AM
    Tadman95
    Tadman95 Active Member
    Mayberry
    2008 Tacoma, 4X4, 4.0L, Off Road Pkg #1
    It does not. I bought two thinking it did. Guess I have a spare.
  5. Jul 10, 2019 at 2:35 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    @Tadman95 Thanks for posting back. I was trying to look at the parts diagram and see they have slightly different part numbers.
  6. Jul 16, 2019 at 9:15 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    UPDATE.... Marvel mystery oil and PB blaster did not work stripped the plug tonight was able to get it out with a large torques driver that I just pounded in the hole..... will be picking up a new plug tomorrow probably going with the Lexus model with the socket and on it
  7. Jul 16, 2019 at 9:31 PM
    Muddinfun
    Muddinfun Well-Known Member
    Marvel mystery oil, PB Blaster, acetone and ATF are not going to do a thing for a drain plug with a crush washer. The penetrating oil is not going to make it past the crush washer. The threads are already submerged in gear oil. The reason a hammer and chisel works is because you are smashing the crush washer thinner, while relieving the tension on the threads and spinning the plug at the same time.
  8. Jul 16, 2019 at 9:51 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    It's adrain plug, torque wrench is not required
  9. Jul 16, 2019 at 10:19 PM
    Taco-Obsessed
    subd for future purchase
    thanks OP
  10. Jul 16, 2019 at 10:41 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Marc70, syswalla and tacoman45 like this.
  11. Jul 16, 2019 at 10:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does this use the same crush washer as old one?
  12. Jul 17, 2019 at 2:24 AM
    Benny123
    Ben
    South Charlotte, NC
    After struggling for an hour, took to a local shop to have them take it off. Took them 45 mins. $30. New plug installed. F that original design.
    Tip. Try a ratchet and 18 in cheater pipe after lubricant of your choice. Impact strips. Breaker bars have difficulty with the angle.
    Ory69 and Norton like this.
  13. Jul 17, 2019 at 5:35 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    The best way to get the OE style drain plug out is with an impact gun and impact rated hex bit- the impacting of the gun works so much better than a breaker bar or long handle ratchet. I've torqued mine properly and a few years later have not been able to break it loose with a breaker bar - but the impact zips it right out. I wish I could explain why a plug submerged in gear oil is so hard to remove :)
    Marc70 and Norton like this.
  14. Jul 17, 2019 at 6:17 AM
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    Simple really. It's hard to remove because there is a massive amount of thread engagement and crush washer contact at a diameter that is too large for the size of the tool hex diameter. Threads of this size normally have torque values well into the 3 digit range.
  15. Sep 16, 2019 at 6:01 AM
    #35
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Ordered.
    Thanks, OP.
  16. Sep 23, 2019 at 11:25 AM
    #36
    CHUCK W
    CHUCK W Well-Known Member
    Does anyone have a different part number for this plug. I checked a Lexus Dealer in Greenville, SC and the number didn't come up. Maybe a vehicle model?
  17. Sep 23, 2019 at 12:12 PM
    #37
    Muddinfun
    That's the number. I just bought 1 from a Lexus dealer about a month ago. I went to a Toyota dealer 1st, and they couldn't get it. Even though Toyota and Lexus are in bed together, that's a Lexus only part.
    RobP62 likes this.
  18. Sep 23, 2019 at 12:36 PM
    #38
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Which is weird because my Toyota dealer had oil pan crush washers for my Lexus.
  19. Sep 23, 2019 at 1:32 PM
    #39
    Taco-Obsessed
  20. Sep 23, 2019 at 1:42 PM
    #40
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    HillJackJDS likes this.
