Front diff drain plug alternate part
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, May 24, 2020.
  1. May 24, 2020 at 6:15 AM
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    Cross post from the 2nd gen forum, in case you don't wander over there.
    Hey folks. You are all likely well aware of the front diff drain plug short comings. I've been using Lexus part # 90341-24016 for a couple of years now... it has a 14mm nut in place of the 10mm female hex, all other dimensions and features are the same. Retail is $10ish.
  2. May 24, 2020 at 6:40 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Can you get a magnetic plug for it ?
  3. May 24, 2020 at 7:48 AM
    Jowett
    Brian
    North Adams, MA
    It has a magnet, just like the original.
    Big tall dave likes this.
  4. May 24, 2020 at 9:28 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
  5. May 24, 2020 at 9:55 AM
    Jowett
    Brian
    North Adams, MA
  6. May 24, 2020 at 9:58 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    What is wrong/bad about the original/factory plug?
    over60 and JNG like this.
  7. May 24, 2020 at 10:02 AM
    Jowett
    Brian
    North Adams, MA
    They tend to occasionally round out due to the smallish 10mm internal hex. It is a bit small for the thread and gasket size engagement on the relatively massive plug. It works well on the smaller plugs.
    DAS Taco and suaveflooder like this.
  8. May 24, 2020 at 10:05 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    They're essentially removed with an allen wrench of sorts. So they strip easily are are difficult to unscrew.
    The Lexus version allows you to use a socket wrench.
    Shamal, DAS Taco and DavesTaco68 like this.
  9. May 24, 2020 at 10:31 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Nothing wrong with the factory plugs. Buy quality tools that won't strip fasteners out. Front diff plug torque is 48 ft/lbs for drain and 29 ft/lbs for fill. Over tighten these and yes, I can see where you would strip them out.
    Here is the proper 10mm hex socket for the factory plus it is made in America as well. I'm sure Snap-On or Mac offer similar sockets.
    https://www.mcmaster.com/8367A47
    Boghog1, 01 dhrracer and over60 like this.
  10. May 24, 2020 at 11:08 AM
    Jowett
    Brian
    North Adams, MA
    In a perfect world, it does ok... but I prefer to plan for the worst. The 14mm will be superior when things go wrong.
    Shamal and DAS Taco like this.
  11. May 25, 2020 at 6:15 AM
    DAS Taco
    DAS
    2017 TRD Offroad
  12. May 25, 2020 at 8:55 AM
    SRBenjamin
    Benny
  13. May 25, 2020 at 9:00 AM
    SRBenjamin
    Benny
    Sorry guys, I was thinking of the rear diff. I've not changed oil in my front yet.
