Front diff drop kit with 2" lift?
Discussion in 'Suspension' started by goufcustom, Jan 30, 2012.
  1. Jan 30, 2012 at 11:35 AM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    Lifting the front 2" this weekend, do I need or is it recommended to install a front diff drop kit? I have a TRD OffRoad 4x4. Everything I have read says you must install one in a 3" lift, but figure it is safer to ask.
    Also the kit looks like just some washers/spacers, should I do a half drop on it and just install some grade 8 washers from the local store to drop it hall the distance that a drop kit does? This I would assume would not require the longer bolts.
    Thanks
  2. Jan 31, 2012 at 8:48 AM
    goufcustom
    MD
    No one?
  3. Jan 31, 2012 at 8:49 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    its not needed at 2 inches of lift. your good:) and on 2nd gens they arent as effective as 1st gens
