Front diff fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_smurfo, Sep 3, 2024.
  1. Sep 3, 2024 at 7:24 PM
    el_smurfo
    el_smurfo [OP] Well-Known Member
    Sae 80 is recommended in the manual. Lots of folks say just use 75w90 in both. Any recommendations?
  2. Sep 3, 2024 at 7:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pick one, pour it in.
    I picked 85w140. Mine leaked out the front breather when temps got cold.
    If you are lucky, yours will too. Most don’t, but some will
    Never seen or heard of 75, 80, or 90 doing it.
    So I’d recommend one of those.
    No need to get too technical. The front differential isn’t a precision part.
    winkel and Why I oughta... like this.
  3. Sep 4, 2024 at 5:08 AM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    spitdog and Revelations like this.
  4. Sep 4, 2024 at 7:50 AM
    TacoTuesday1
    FL
    Relocate the breather.
    75w90 is common. Extreme pressure gear spec. It’s not picky on brass synchro chemical spec.
    I use 75w140 because that’s what ECGS recommends if not more. Truck is regeared.
    only downside is at ambient temp it’s thick which made getting it in with my plunger not easy. Didn’t have a different style easier pump.
  5. Sep 4, 2024 at 9:13 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Where to? It's already up in the engine compartment.
    TnShooter likes this.
  6. Sep 4, 2024 at 11:51 AM
    TacoTuesday1
    FL
    they all can be made higher. It’s not high up in the engine compartment. They also clog. And I believe come as one way from the factory instead of two way which might be better.
  7. Sep 6, 2024 at 6:11 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Redline 75x90 front and rear diff. GTG.
