Front Diff Problem???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huntark03, Aug 16, 2010.
Front diff noise??
Poll closed Sep 15, 2010.
  1. I have a lift and have a grinding noise coming from my front diff.
    10 vote(s)
    21.7%
  2. I don't have a lift and have a grinding noise coming from my front diff.
    3 vote(s)
    6.5%
  3. I have a lift and haven't ever had a problem with my front diff.
    15 vote(s)
    32.6%
  4. I don't have a lift and haven't ever had a problem with my front diff.
    18 vote(s)
    39.1%
  1. Aug 16, 2010 at 11:48 AM
    huntark03
    huntark03 [OP] I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    How many people out there have had the noise problem out of their front differential...lift or no lift? I am thinking about leveling my truck with front and rear Billies and maybe Eibach coils but don't want to have to deal with any bearing problems... It seems like some people have the problem without a lift too...
  2. Aug 16, 2010 at 11:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    You shouldn't have bearing problems from lifting. If you develop them, it's because it was a pre-exsisting condition.
  3. Aug 16, 2010 at 12:05 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    could get a diff drop kit
  4. Aug 16, 2010 at 12:19 PM
    huntark03
    Maumelle, AR
    So in your opinion...the possibility shouldn't impact my decision?
  5. Aug 16, 2010 at 12:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, IMHO the possibilty should not impact your decision.
  6. Aug 16, 2010 at 12:47 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Theres always a possibility, but not a probability
    (did i spell all that correct? haha )
  7. Aug 16, 2010 at 12:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    possibly............:D
  8. Aug 16, 2010 at 12:51 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I had to get a new front diff... but who the fuck knows what the problem was... I kept burning up axle seals.
    The dealer said the diff was chewed up due to lift (previous 3" lift, but I don't really believe them)
    either way I let them replace the front diff and axles... it was free (warranty)
  9. Aug 16, 2010 at 12:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    How long ago? And have you had an issue since?
  10. Aug 16, 2010 at 12:56 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    about a month ago... no problems now
    I personally think that it was either a quality defect or the dealer fucked up the first axle seal install... but then again how did it fail in the first place?
    The Dealer to fix it under warranty no questions asked... they even painted it as them doing me a favor
  11. Aug 16, 2010 at 12:58 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    speaking of which I should go look under the truck...
    there was popping sounds and leaking oil before... there hasn't been a single pop since the diff was replaced.... the funny thing is that my cv were fine, so I don't know if the lift caused the problem
  12. Aug 16, 2010 at 1:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    I am inclined to agree.
    If lifting had a negative affect on the fornt diff, there would be a hell of a lot of more threads stating so. Second, the only reason people install a diff drop (and not everyone does) is to correct CV angles to keep the boots from wearing/ripping.
  13. Aug 16, 2010 at 1:31 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I agree... the only other problem could have been during the install of the RCD lift... we had to remove the front diff and the axles might have been at extreme angles during the install
  14. Aug 16, 2010 at 1:42 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I took the diff drop off my truck this weekend. The drive line seems smoother now. I used to get the pop all the time but I have not heard it since may :notsure: :knockonwood:
  15. Aug 16, 2010 at 2:04 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Agreed...sort of. The possibility exists that you have a bad bearing in the front differential right now (as was the case when people lifted the truck and got the front diff vibe). It's not that the lift caused the vibration, but rather the lift caused the bearing to manifest its true condition. If the bearing is going bad, you'll hear it at stock levels eventually.
    Whether you want to deal with it if you lift it and find that you have the problem, that's your "make or break" decision. Only you can answer that question. It isn't a matter of odds where the poll gives you your answer. Personally, I would lift it sooner while you're still under warranty because then you can have it replaced on Toyota's dime (well, actually $2K). Waiting until after the warranty has expired to lift your truck is a mistake IMO because then you have to pay out-of-pocket for the defective part that was covered under the drive train warranty.
  16. Aug 16, 2010 at 5:19 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I've had a 3" lift (885's with 1/2" spacers) for about 40k miles and my front diff makes all sorts of terrible noises. In the end though, I have not wanted to remove my lift, nor would I not lift it knowing of the possible problem. Because it is such a rare issue I think its worth the risk.
    It seems that the lift just sped up the bearing problems, but I think that it would still happen lifted or not.
    Mine has been making noises for almost a year, and it hasn't gotten any worse. So to me it doesn't warrent replacing the differential untill the noises get worse. All I may do eventually when I can afford to put my truck down for a week is replace the bearings (along with CVs and wheel bearings and other suspension bushings)
  17. Aug 17, 2010 at 6:20 AM
    huntark03
    Maumelle, AR
    Thanks for the replies folks! I'll probably go ahead and get the Billies and then save up for the coils!!! I have the rear leaf TSB done this Wednesday and I don't like the nose down look!
  18. Aug 22, 2010 at 11:28 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I wheel a little and use my truck as a large mountain bike - no problems with my front diff.
  19. Aug 23, 2010 at 12:02 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  20. Aug 23, 2010 at 7:21 AM
    HBMurphy
    Paul
    So California Coast
    None
    The pemise of this poll is a bit short - The idea of putting data together on this solely on idea of if it is lifted may be a bit short. If this included actual height, brand of UCA, tread pattern and mileage, if cv's a have failed, and if they used a 'diff drop' we may get a better insight.
