Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Feb 26, 2017 at 6:56 PM
    #181
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Just one. Drivers side only.good luck take your time.
    Joe23[QUOTED] likes this.
  2. Feb 26, 2017 at 7:09 PM
    #182
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    what guy that does your lift?
    I have an rhythmic hum when I am coasting its off and on with the revolution of the tire. I thought it was the drive shaft or rear diff...
  3. Feb 26, 2017 at 7:16 PM
    #183
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    It's being installed by the shop doing the lift. I don't have the tools or time to do it all myself like I used to.
    But thanks for quick reply
  4. Mar 3, 2017 at 9:08 AM
    #184
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    I am on a Gen2 but like this thread...I've decided to do this fix too.
  5. Mar 8, 2017 at 2:21 PM
    #185
    hodo_taco
    hodo_taco Well-Known Member
    Colorado Springs, CO
    '16 SW Tacoma DCSBTRDOR
    Lot's o' plastidip.
    Fantastic details, thanks for sharing. Planning to do the install this weekend. Did you top off with the fluid you linked to or do a full drain/replacement?
  6. Mar 9, 2017 at 8:28 AM
    #186
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    When pulling the CV axle out the differential drains. I did a full replacement of the diff fluid with the oil I mentioned.
  7. Mar 10, 2017 at 8:51 AM
    #187
    hodo_taco
    Lot's o' plastidip.
    How many quarts are needed for a full replacement?
  8. Mar 10, 2017 at 4:39 PM
    #188
    jrlin718
    Jonathon
    Louisville, KY
    I believe it's 1.6 qts but you may want to double check your manual
  9. Mar 10, 2017 at 8:29 PM
    #189
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    Anyone have the removal tool I can purchase or borrow?
  10. Mar 17, 2017 at 8:58 AM
    #190
    hodo_taco
    Lot's o' plastidip.
    I'm doing mine this weekend I believe, so I will have the tools available next week more than likely.
  11. Mar 17, 2017 at 8:59 AM
    #191
    hodo_taco
    Lot's o' plastidip.
    Dumb question for everyone, but is an alignment required after performing this work?
  12. Mar 17, 2017 at 6:03 PM
    #192
    not0ny
    Thanks I purchased it actually
  13. Mar 17, 2017 at 10:36 PM
    #193
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Theres one floating around that people are borrowing, just need to pay shipping. Cant remember the thread.
  14. Mar 18, 2017 at 6:34 AM
    #194
    jrlin718
    Jonathon
    Louisville, KY
    Just figured I'd post an update. Did the ECGS needle bearing replacement a few weeks ago. Since then have about 400 miles on it. The noise before was the worst when it was cold. Even at 20 degrees it was still silent. Love ECGS. Good luck everyone else. The only regret I have is not doing it sooner.
    VA SOFTACO likes this.
  15. Mar 18, 2017 at 5:23 PM
    #195
    Atomic
    New Mexico
    Done with the ECGS job. Getting the CV axle out/in was a bitch...the needle bearing was easy with the tool.
    Tool is available ($30 - incl. shipping). PM me.
    16TRDoff_road and VA SOFTACO like this.
  16. Mar 19, 2017 at 1:55 PM
    #196
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    not needed unless it's been a while and you just want to get the alignment fine tuned anyway.
    hodo_taco[QUOTED] likes this.
  17. Mar 20, 2017 at 8:44 AM
    #197
    hodo_taco
    Lot's o' plastidip.
    Thanks, wasn't sure since you have to remove the tie rod end.
  18. Mar 20, 2017 at 8:52 AM
    #198
    hodo_taco
    Lot's o' plastidip.
    Finished swapping the ECGS clamshell bushing in yesterday. Wasn't too hard, but encountered some issues I hadn't expected:
    1. Getting the new bushing in, even with the special tool from ECGS, wasn't as easy as I thought. It's tough to get it lined up perfectly straight.
    2. Refilling the diff fluid was a pain. Would definitely get a pump tool next time I have to do that.
    3. I recommend using a "no damage" tie rod end separator tool instead of the fork tool. I didn't know this existed until AFTER I had torn my boot trying to get that thing off.
    I've got the Driver tool for getting the new bushing in, just PM me if you're interested. Already sold the ECGS removal tool.
  19. Mar 25, 2017 at 3:04 PM
    #199
    not0ny
    Anyone in the Las Vegas / Henderson area hit up DH Customz 808!! Daryl lifted my truck with bilstein 6112s and 5160s and replaced my needle bearing bushing with the ECGS one.
    Killer deal on installation and hes quick! Got my truck back in 3 1/2 hours. I left the ECGS installation tool with Daryl so anyone in the area that needs that done hit him up!
    https://www.yelp.com/biz/dh-customz-808-henderson
  20. Mar 25, 2017 at 3:44 PM
    #200
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Did my ECGS bushing today. Never taken my CV axles off before so that was an experience. I was also amazed to see that i got my needle bearing out without breaking it. Anyway put the new one in and all is well in the world, thanks for all the help on this thread guys
    mcharfauros likes this.
