FRONT DIFFERENTIAL DROP!!!!!!!!!! xD
Discussion in '1st Gen. Tacomas (1995-2004)' started by atapia22, Mar 1, 2011.
  1. Mar 1, 2011 at 12:43 PM
    atapia22
    atapia22 [OP] Well-Known Member
    Imperial Valley
    Tacoma 1995 4x4
    I want to ask for help about how to drop a differential(front) for a 4x4 '95 Toyota Tacoma. Is it really that difficult because I see the drop kit and i see bolts and screws xD, Thank You.
  2. Mar 1, 2011 at 12:45 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's simple it takes about 15min to install
  3. Mar 1, 2011 at 1:20 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Its a simple install a little more than 15 mins IMO if you deal with a skid plates, I usually time a job from the time I read the directions to the time I put my tools and equiptment away. my 0.02
  4. Mar 1, 2011 at 1:44 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Very easy instructions tell you all 3 steps lol
  5. Mar 1, 2011 at 7:38 PM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    u know where i can get the steps to put it? ?
  6. Mar 1, 2011 at 7:38 PM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    the instructions come with the kit?
  7. Mar 1, 2011 at 7:51 PM
    tacomakid96
    Phil
    Out n' about
    Mine did, I got it from fat bobs
  8. Mar 2, 2011 at 7:19 AM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    ive been reading on other threads and sying that eibachs cause vibration, even with the diff drop, what do u have on ur taco?
  9. Mar 2, 2011 at 7:39 AM
    tacomakid96
    Phil
    Out n' about
    Daystar 2.5 spacer, it rides like hell off road and I have gone through 2 sets of upper ball joints. I think I'm gonna go with OME 881's nitro chargers and rear aal this summer.
  10. Mar 2, 2011 at 10:42 AM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    so u dont recommend the eibach springs ? ?
  11. Mar 2, 2011 at 10:51 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    eibach makes a good spring, but for the price OME makes a better coil IMO and you get more lift out of it then you would with the eibach about 1.5 inches more
  12. Mar 2, 2011 at 11:01 AM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    WHAT POUNDAGE WILL IT BE FOR A 95 4X4 TACOMA?
  13. Mar 2, 2011 at 11:23 AM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    or if its not a prob can i get a website? TY
  14. Mar 2, 2011 at 11:26 AM
    tacomakid96
    Phil
    Out n' about
    881's if you don't have a bumper or a winch
  15. Mar 2, 2011 at 12:03 PM
    atapia22
    Imperial Valley
    Tacoma 1995 4x4
    ok ty very much
  16. Mar 2, 2011 at 1:40 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    checkout for all OME setups, they will tell you what you need which like taocmakid said would be 881's unless you're planning on putting a bumper or winch
  17. Mar 2, 2011 at 1:57 PM
    tacomakid96
    Phil
    Out n' about
    This is the next lift I'm gonna get
  18. Mar 2, 2011 at 2:00 PM
    JLee
    Jerry
    Benicia, CA
    Are you saying you will get more lift with the OME over the Eibachs? :notsure:
  19. Mar 2, 2011 at 2:01 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    FWIW, diff drops dont actually change cv angles
  20. Mar 2, 2011 at 2:04 PM
    JLee
    Jerry
    Benicia, CA
    It does on 1st gens
