FRONT DIFFERENTIAL DROP!!!!!!!!!! xD
Discussion in '1st Gen. Tacomas (1995-2004)' started by atapia22, Mar 1, 2011.
  1. Mar 2, 2011 at 2:04 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    it changed my angles bigtime! Idk about second gens.
  2. Mar 2, 2011 at 2:09 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    hmmm. it seems its almost identical... it drops the front bracket which lowers the front, but where the actual axles are just turn, they dont drop
  3. Mar 2, 2011 at 11:02 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    the only reason why i say that is because i have experienced it myself, this being with the bilsteins set at the lowest setting (stock) the OME coils gave me more lift in the front than eibach. I'm assuming you could set your perch (assuming you had bilstein 5100) to the middle with the eibach and probably get around the same lift but then again you're compromising ride quality the higher you set that perch. Either coil is a damn good product just depends on the person and/or application
  4. Mar 3, 2011 at 10:36 AM
    atapia22
    atapia22 [OP] Well-Known Member
    Imperial Valley
    Tacoma 1995 4x4
    nicee thank you, i think im going with the OME :goingcrazy::goingcrazy::goingcrazy:...
  5. Mar 3, 2011 at 1:56 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    i'll take some rep points... :p
  6. Mar 3, 2011 at 2:00 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You must of got the wrong Eibachs because you can't set the Eibachs to another spot other then 0 on the 5100's and my Eibachs gave me 3 1/2" of lift and if your getting any more then that with OME your going to rip you CV boots apart. And from what Ive read the OME coils don't even give a full 3" lift with out the top plate spacer.
  7. Mar 3, 2011 at 2:19 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    I'm not sure exactly what eibachs they were, what i am saying is that i had bilstein shocks with both eibach and OME (set at 0) and the ride IMO was better with OME and i didnt get as much lift with the eibachs.
  8. Mar 3, 2011 at 2:25 PM
    JLee
    Jerry
    Grass valley CA
    :notsure: crazy you must not of had the Toytec coils then because they give 3+ inches of lift. What OME coils do you have now.
  9. Mar 3, 2011 at 2:28 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    no i didnt have the toytec eibachs, the pair i had were bought through a local shop and the OME coils were 881's but they werent on this truck they were on my previous 2002 my truck i have now just had stock coils with billsteins at the middle perch nothin special
  10. Mar 3, 2011 at 2:34 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The Gen 1 trucks are mounted completely differently. It does help on the pre-05 rigs.
  11. Mar 3, 2011 at 2:41 PM
    JLee
    Jerry
    Grass valley CA
    I see the Eibachs that everyone talks about here are Toytec and they give more lift then the 881's but the 881's are a lot softer so the ride will be better.
  12. Mar 3, 2011 at 7:06 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i dont mind it being stiff, it probably saved some random parts when i accidentally hit a deep rut on the road kinda fast and bottomed out my suspension.. if i had any softer spring i woulda had some damage plus they look sexy with them 5100s
  13. Mar 3, 2011 at 7:10 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    this is right
  14. Mar 3, 2011 at 7:12 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    e-coils= highest lift coil also stiff
    ome with ome shock= not a full 3 inchs without top plate.
    ome coil on 5100= with 881 and 5100 you can get 3 inches of lift best option if the full 3 inches is important.
    ome full setup=best out of the pile if the full 3 inches isnt important
    5100 on stock coils=2.5 inch lift still good ride quality, good lift on the cheap..
    Any thing else?
  15. Mar 3, 2011 at 7:46 PM
    #35
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    good call good call
