Front Differential Needle Bearing Failure: Related to Fluid Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigSkyTR6, Sep 29, 2020.
  1. Sep 29, 2020 at 7:26 PM
    BigSkyTR6
    BigSkyTR6 [OP] Active Member
    2014 V6-6MT Access Cab
    TRD Skid Plate TRD Shift Knob
    I have owned my Tacoma for about two years and this will be my first post here. For reference, the truck is a 2014 Access Cab with the 4.0 and 6MT. I bought it used at 41K miles and it now has just under 64K miles. The truck was purchased with 265/75 AT tires; it now has 245/75 Defenders. The truck is otherwise completely stock. Since it had an incomplete service history when I bought it, the drivetrain fluids were changed at 42K at the dealer. I changed the fluids again at 61K miles with quality brands available locally: Schaeffer’s 75w-90 in both front and rear diffs.
    Over the weekend, it developed the dreaded rumble/vibration consistent with the needle bearing in the front differential at highway speed. I checked today and there is quite a bit of play on the drivers CV at the diff. I can move the axle up/down and left/right at the differential case.
    Because this has happened relatively soon after a differential fluid change (about 3K miles) is the failure of the bearing directly related to the weight or brand of oil? Has any connection been made to these failures and use of a different oil than the factory fill? Or is it just bad luck?
    Gunshot-6A likes this.
  2. Sep 29, 2020 at 7:41 PM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    No. It just happened. That is kinda low mileage, but, regardless, it sounds like it needs to be replaced with the ECGS bushing. I'm sure your diff lube is probably fine, but I used Valvoline 75W-90 when I did the ECGS bushing and no issues 15 months later. You'll have to replace diff lube when you do the ECGS, but I'm sure any reputable 75W-90 is fine for the front diff.
    Ol'gray mare and Gunshot-6A like this.
  3. Sep 29, 2020 at 8:14 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    To be sure it’s the bearing, does the vibe go away in 4hi?
  4. Sep 29, 2020 at 8:27 PM
    BigSkyTR6
    I have not done the 4-HI test yet. I had enough time to inspect/grease the rear driveline and inspect the front CV axle.
    The vibration occurs at 45MPH and up. Is there any harm in engaging 4-HI at that speed on dry pavement?
  5. Sep 29, 2020 at 8:34 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    I would chalk it up as coincidence. I also wouldn't consider 3k miles after changing the oil to be close enough in use to be suspect.
  6. Sep 30, 2020 at 4:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're fine as long as you drive straight
    whatstcp and Gallowbraid like this.
  7. Sep 30, 2020 at 12:17 PM
    BigSkyTR6
    One more question to ease my mind: When I did the last fluid change, I started with 5 quarts of 75w-90 and finished with 1/3 bottle or less for both diffs. I swear I filled both until fluid ran out the fill opening, but I am now doubting my work. Could an under-filled front differential cause this bearing to fail?
  8. Sep 30, 2020 at 12:28 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I think it's 3 for the rear and just under 2 for the front. Since there will be residual oil in there no matter how long you drain it, I think you're good. You did it on flat ground?
  9. Sep 30, 2020 at 12:30 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    My needle bearing and driver's hub both went bad right around 60K and simultaneously. ECGS for the new needle bearing and there's a memeber on here that does the hubs for a good price if it isnt under warranty still.
    dk_crew likes this.
  10. Sep 30, 2020 at 12:38 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Modern oils and grease (chemistry) are so good. Just stay within OEM spec and purchase from a reputable vendor. I started buying Costco motor oil and have no regrets.
    whatstcp likes this.
  11. Sep 30, 2020 at 1:00 PM
    BigSkyTR6
    I just ran around the block to do the 4-HI test. Results are inconclusive as the truck had to be warm for me to hear/feel the issue. There may be a difference there, but I need a longer drive to get more heat in the truck.
    And yes - the diffs were refilled on level ground with all four tires on pavement.
  12. Sep 30, 2020 at 4:13 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Get under the truck and grab the axle on the end that goes into the front diff and see if it has play in it. Shake it and see if it moves at all.
  13. Sep 30, 2020 at 4:31 PM
    BigSkyTR6
    Thanks for the reply. I can move the end of the drivers CV axle up/down and fore/aft at the differential. The play is rather noticeable, I.E. it is more than a few thousandths. I am pretty convinced that I have the needle bearing problem.
    Ol'gray mare likes this.
  14. Sep 30, 2020 at 4:37 PM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    I would say you have a needle bearing issue. I replaced mine at around 72k. After the ECGS bushing problem solved. Mine had the same play at the diff you are describing.
  15. Sep 30, 2020 at 4:38 PM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    cryptolime likes this.
  16. Sep 30, 2020 at 4:39 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You sure the front suspension is stock? Play in the CV shaft is fairly common in even fairly new trucks, but usually doesn't cause vibration at stock height because the CV shaft sits level (negligible side forces on the bearing).
    Cold vs warmup shouldn't have any effect on the front diff because it isn't transmitting power in 2WD.
  17. Sep 30, 2020 at 4:49 PM
    BigSkyTR6
    I believe the suspension is all stock. The truck is an SR5 (no TRD packages) and I don’t see any spacers in the front struts. Here are some quick measurements from a relatively level driveway to the bottom of the over-fender, right at the centerline of each wheel:
    LF: 33 78”
    LR: 36”
    RF: 34”
    RR: 36 1/2”
    Again, these are with a 245/75 Defender tire. Is this in the ballpark for a stock SR5?
  18. Sep 30, 2020 at 4:50 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Yeah unfortunately these trucks have a few weak points and that’s one of them. On the plus side it’s a pretty easy and inexpensive fix.
