Front Differential(?) Vibration after lift
Discussion in 'Suspension' started by davidpick, Feb 25, 2011.
  1. Feb 25, 2011 at 8:19 AM
    davidpick
    davidpick [OP] NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    Alright, here's a question for folks much more knowledgeable than me in the ways of truck mechanics:
    I have a 3" suspension lift/level on my 2000 Tacoma 4x4, and I'm getting some pretty nasty vibrations/"whirring" at any speed above 40mph. I feel it in the floor of the truck (i.e. with my heels) and slightly in the steering wheel. What could this be and how do I take care of it?
    Front lift specs:
    5100s (set at 0") with Eibach coils
    Differential drop kit
    Light Racing UCAs
    Rear lift specs:
    5100s
    Toytec AAL
    3-degree axle shims
    Things to note:
    I just added the LR UCAs and Eibach springs 2 weeks ago and that's when this started. Before that, I had the 5100s set at 2.5" on the OEM springs and only had a minor vibration from the rear driveline between 40 and 55 (but I think a carrier bearing drop would cure that)
    Three weeks ago, I swapped out my OEM 15x7 Toyota Alloys with 15x8 Eagle Alloys (and kept the same tires -- BFG TA KO)
    I bought a grease gun and lubed all the fittings on the front/rear driveline and seems to have smoothed things out only the tiniest bit (but I thought I'd start with the cheap/easy stuff first)
    Thoughts?
    Pics below show my CV axle angles after the diff drop:
    Passenger:
    Driver:
  2. Feb 25, 2011 at 9:30 AM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    This may be a dumb question.. but did you have it aligned after all of this??
  3. Feb 25, 2011 at 10:15 AM
    davidpick
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    yep, got it aligned.
    Settings:
    Toe (L/R): .04" / .05"
    Camber (L/R): .01 deg / .03 deg
    Caster (L/R): 2.35 deg / 2.4 deg
