front differential
Discussion in 'Technical Chat' started by linkfeeney, Feb 19, 2011.
  1. Feb 19, 2011 at 7:47 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    can anyone where post a pic where the front differential drain and full plug is?
    I have a V6 on mine, cause I can't find it. :confused:
    well, I dont have this black plate in the way thou. :rolleyes:
  2. Feb 19, 2011 at 8:03 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    The drain/fill plug on the front diff is right inside the frame behind the driver side lower control arm.
  3. Feb 19, 2011 at 8:35 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    is on the driver side? ummm...i never looked over there
    hook me up with a pic if u can later on please? :) thank you
  4. Feb 19, 2011 at 8:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Fig shows drain and fill plug locations, as well as torque values.
  5. Feb 19, 2011 at 9:09 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I was looking all over the place for that fill and drain plug
    then i saw on it on the last page.
    it says not a reusable part, the gasket. that sux
    thanks chris4x4
  6. Feb 19, 2011 at 7:54 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Gasket are usually never reusable.
  7. Feb 25, 2011 at 7:03 PM
    JakeInGrayTacoma
    JakeInGrayTacoma Active Member
    Jake
    SoCal Mtns
    95 4x4 gray tacoma
    Get back up to snuff cuz it wasn't maintained. I got xm radio in it.
    I replaced the diff fluid on the rear axle today! Sure enough 2.5 bottles of fluid. Then it was onto the front...where to fill...found the plug listed on the above df-18, but didn't have the appropriate tool to unscrew the plug. Where do I get the replacement gasket for these plugs?
