Front Diff's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gearhead06, Nov 15, 2010.
  1. Nov 15, 2010 at 5:15 AM
    gearhead06
    gearhead06 [OP] Active Member
    josh
    columbus
    07 Tacoma v6 4x4
    I have a 3" lift from suspensionconnection.com... I have 4.88 gears Front and Rear with 2 Arb Lockers.. Im running on some 315/75R16 FIERCE ATTITUDE M/T...
    Ok so im working on putting new gears and a locker in my front diff i have it all out the diff the cv axles and the front drive shaft but i was wanting to know if any one knows if i can still dirve the truck with OUT my cv axles in there???? so if any one knows PLZ let me know...
    im selling my 3.73 front gears if any one wants them....
  2. Nov 15, 2010 at 6:46 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not with out the part that is bolted to the wheel. So practically No.
    Unless you want to take a part CV and just bolt tulip back to hold bearing together, then cover with something to don't get dirt inside.
  3. Nov 15, 2010 at 6:54 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Nailed it. The outer CV and the nut that holds it in place keeps the wheel bearings where they need to be.
  4. Nov 15, 2010 at 6:57 AM
    gearhead06
    josh
    columbus
    07 Tacoma v6 4x4
  5. Nov 15, 2010 at 7:11 AM
    Chasetyler19
    Chasetyler19 Tacoma's Rule
    Chase
    Junction City, KS
    06 Tacoma SR5 4x4
    6" Fabtech Suspension liftkit on 35x12.50 Dick Cepek Mud Country tires on 17" DC1's, Afermarket tinted windows, Volant Cold Air Intake.
    Where did you purchase your new gears and how much did everything cost?
  6. Nov 15, 2010 at 10:29 AM
    gearhead06
    josh
    columbus
    07 Tacoma v6 4x4
    FOR MY FRONT AND REAR IM PUTTING IN 4.88 AND ARB LOCKERS IN MY FRONT AND REAR DIFF'S WITH THE BIG ARB AIR COMPRESSORS FOR $2700.00 AND THATS WITH THE INSTALL KITS TOO... I GOT THEM ALL FROM http://www.ringpinion.com/ I HAD TO CALL THEM AND TALK TO THEM CAZ I COULD NOT FIND ANYTHIN ONLINE THERE NUMBER IS 1-866-631-0196:)
  7. Nov 15, 2010 at 10:32 AM
    BlueT
    NorthEast
    4.88 is pretty low, what tire size are you planning to run? 35's?
  8. Nov 15, 2010 at 11:07 AM
    gearhead06
    josh
    columbus
    07 Tacoma v6 4x4
    IM ABOUT TO GET A SOME NITTO MUD GRAPPLERS IN 315/75R16
  9. Nov 15, 2010 at 11:45 AM
    finecamaro69
    finecamaro69 Member
    Charlotte, NC
    06 TRD sport 4WD
    2" spacer Suspension lift, Dakar Leafs
    Are you selling the front and the rear set of gears? I'm looking to go back to 3.73 from 4.10 and going backwards is a little harder to find parts.
  10. Nov 15, 2010 at 11:50 AM
    BlueT
    NorthEast
    Ha ha they are 35's :D awesome
  11. Nov 15, 2010 at 1:12 PM
    gearhead06
    josh
    columbus
    07 Tacoma v6 4x4
    MY REAR GEARS ARE NO GOOD THATS WHY I WENT TO 4.88
  12. Nov 15, 2010 at 1:15 PM
    finecamaro69
    finecamaro69 Member
    Charlotte, NC
    06 TRD sport 4WD
    Ok thanks for the reply.
