Front Driveshaft U-Joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toysrgood, Jun 16, 2017.
  1. Sep 10, 2019 at 8:24 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup it should
  2. Sep 10, 2019 at 8:32 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    why are the auto stores so expensive???? It just seems nuts and just driving everyone to buy online
  3. Sep 10, 2019 at 11:00 AM
    81shark
    81shark Well-Known Member
    Because they are there and have the part you need today... I think i paid 21+ tax for the spicer greasable u joint at napa. I was pleased
  4. Sep 10, 2019 at 5:51 PM
    HumanityForPresident01
    HumanityForPresident01 Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    Thanks, i commited to the buy before asking you - i always second guess myself.
    As in when i called the dealership to see how much front ujoints were... 74 dollars... A piece.
    GET the eff otta here! :D:D:D second guessed myself onto Amazon and got 4 for 70 something.
    Eff you toyota and your b.s.:amen:
  5. Sep 11, 2019 at 2:22 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Anytime I pull any driveshaft out for u-joints I get the machine shop to do it and always rebalance. Many will disagree but even my front was balanced as I have done lots of long rough gravel dirt roads in 4Hi so why not make sure it does not vibrate and mess the case bearings up. Napa usually can do them. Most larger areas have a driveline specialty shop that does the diffs, all bearings, xfer cases and driveshafts and these are your best friend if you don't want to do it yourself.
    SilverYeti likes this.
  6. Apr 19, 2024 at 12:51 AM
    TacoTuesday1
    SD CA
    does anyone know if it’s worth rebuilding the front shaft with new slicer u joints and balance
    or verify no play and leave it be
    because being 2Hi most of the time, front shaft has probably spun way less miles given 4x is used fraction of the time
    vs main rear propshaft spinning at all times
  7. Apr 19, 2024 at 4:27 AM
    AJwisco
    AJwisco Well-Known Member
    2005 Tacoma sport
    I just threw some new joints in my front shaft, because the the little rubber below the caps was cracked and missing in spots. I did not rebalance, but I don’t run 4x4 at high speeds , if I did I’d have it balanced checked. I’d say check for play, grease, and send it
  8. Apr 19, 2024 at 4:29 AM
    AJwisco
    2005 Tacoma sport
    I also marked the yokes and reinstalled the same orientation it was from factory
  9. Apr 19, 2024 at 2:15 PM
    TacoTuesday1
    SD CA
    guess I’ll look at it
    Yeah that’s what I’m curious about if just sitting there from age had any bad effects regardless of spinning miles
    I’ll ask driveshaft shop what they recommend
    if there is rubber and plastic I’m sure it’s screwed.
    4x is not the smoothest and could be due to front shaft. Not trying to damage a freshly regeared diff by skimping on a shaft connected to it that really would be pretty cheap to refresh.
