Front end feels loose after lift.
Discussion in 'Suspension' started by Bee22971, Aug 14, 2012.
  1. Aug 14, 2012 at 2:29 PM
    Bee22971
    Bee22971 [OP] Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
    Hey guys I need some advice. I installed a set of King 2.5 C/O and DSM UCAs on my 2011 Taco and my truck feels loose. I bought the kings from a fellow member and they looked and road great for about a month. However, now I'm noticing that my steering wheel really moves with the grooves of the road and the front end feels loose in rough wind. I have duratrac 285s on stock rims with 1.25 spacers.
    I've done some searching on TW and haven't found a answer that has corrected the issue yet. I haven't tried tightening my "wheel bearing" as suggested in on thread posted recently.
    Have any of you had this issue before and know what to do to correct it?
    I apologise upfront if this is posted in the wrong section but since it happened after my lift I thought it might be cause by the C/Os or the UCAs.
  2. Aug 14, 2012 at 2:44 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    alignment lately ?
    possibilities:
    ...tire pressure settings too high
    ...alignment is off, castor settings are too vertical
    ...worn rack mounting bushings (common thang)
    ...inner tie rod play (outer also, but rarer)
    ...steering rack pressure guide has worn or has play (internal)
    ...steering rack "end" guides have become worn (look for leakage next)
    ...worn upper or lower ball joints
  3. Aug 14, 2012 at 2:52 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op just go down this list and see what you need these are all the things you gotta look at
  4. Aug 14, 2012 at 2:53 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Go through the front end and torque everything down . All the said stuff above too.
  5. Aug 14, 2012 at 3:10 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Someone suggested your wheel bearing was loose and needed tightening? :laugh:
  6. Aug 14, 2012 at 10:42 PM
    Bee22971
    Garth
    Sacramento
    2011 DC TRD
    My alignment was done maybe a month ago when i got new tires. My alignment printout had me in the green. However, I only had 2.3 & 2.4 degrees caster. My truck has 13k miles and the steering wheel has little to no play. But when I'm @ highway speeds and it's windy or the road sucks my front end feels loose.
    Tomorrow I'll start the project and run down the list of suggestions. Thx 4 the help.
  7. Aug 14, 2012 at 10:46 PM
    Bee22971
    Garth
    Sacramento
    2011 DC TRD
    I was doing some research and another guy had a similar problem and the TW member suggested to "tighten your wheel bearings." It reminded me of my old army days when we use to send the new pvt to go find blinker fluid. It made me laugh so I figure I would add it.
  8. Aug 15, 2012 at 4:38 AM
    XXXX
    sKiP
    05 Prius
    I was going to say he needed to get slapped.
  9. Aug 15, 2012 at 6:15 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Sounds like caster. Might want to get it checked at a different shop.
  10. Aug 18, 2012 at 11:00 AM
    Bee22971
    Garth
    Sacramento
    2011 DC TRD
    Here are my alignment numbers:
    R side
    Camber .3
    Caster 2.6
    Toe .02
    L side
    Camber .4
    Caster 2.5
    Toe .02
    Front
    Total toe .04
    Steer ahead .00
    Tire pressure is 76psi cold and the tires say 80psi
    Any additional thoughts?
  11. Aug 18, 2012 at 8:22 PM
    tomtom
    The Desert SW
    2012 FJ
    76psi? That's got to be one rough ride.
  12. Aug 18, 2012 at 8:23 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    76 PSI is like 40 PSI too high
  13. Aug 18, 2012 at 8:55 PM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    Yikes, the tires say 80 because that's the maximum. But never fill them that high for everyday driving and especially when the road sucks. Drop that down to the 30-35 range ASAP
    P.S. Your Alignment is perfect
  14. Aug 19, 2012 at 8:37 PM
    Bee22971
    Garth
    Sacramento
    2011 DC TRD
    I want to thank everyone who provided suggestions. I found the culprit. The passenger side uca was bad and had significant play. After throwing on another set of ucas and re-alignment the truck drives great again.
