front end growling noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Patrick0625, Oct 13, 2009.
  1. Feb 4, 2014 at 4:40 AM
    #141
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - ICON Stg 1 Adjustable Coil Overs ~3" lift, UCWMS, Airbags
    UCWMS; ICON Stg 1 Adjustable Coil Overs ~3" lift/shocks; Diff drop Spacers; Light Racing UCAs, Firestone Airbags
    This Kit is the what others have used to fix the issue. I ordered and just received my kit, need to get it installed this week:
    http://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing.html
    Cheers
    TyBud850 likes this.
  2. Feb 4, 2014 at 10:46 AM
    #142
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    I had the ECGS bushing installed by a local mechanic and the vibration issue went away. I have the an '06 4.0L 4x4 TRD with an almost 2" spacer lift. I don't think I had the clicking issue you're describing, or if I did I don't remember it. But make sure and remember to replace the CV axle if it shows the slightest wear. I highly recommend this fix before you start replacing other, more expensive parts.
  3. Feb 4, 2014 at 11:35 AM
    #143
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Funny, I hear a similar growling noise when Im in the close proximity of a Frontier. I think my Taco is just being territorial...
  4. Feb 4, 2014 at 8:14 PM
    #144
    ksmoove757
    ksmoove757 Well-Known Member
    Kenneth
    VA BEACH
    2012 Tacoma Sport 4x4
  5. Feb 5, 2014 at 4:33 AM
    #145
    g34rh34d
    Colorado
    If you *believe* it is both then to be sure you can determine if it is the needle (carrier bearing) by driving down the road, and while hearing the growling, place the truck from 2wd to 4wd. If the growling goes away, its the needle bearing. if it does not go away then its likely the outer (hub) bearing, or both.
    Do the 4wd test first. that will help you determine where to look.
  6. Feb 17, 2014 at 2:54 PM
    #146
    g34rh34d
    Colorado
    So I installed the East Coast Gear Supply (ECGS) bushing kit today... The install was pretty strait forward. I made one minor "improvement" to the Bearing puller.. I attached some .032 safety wire to the "puller" portion of the tool. (see pictures). I did this to prevent the possibility of losing the tool in the diff. This minor improvement worked out really well! The total job start to finish took about 3 hours, there was some difficulty getting the CV axle out, but once past that the rest of it went relatively quick.
    The bushing went in as designed, but one suggestion I can make is if you are using the bushing (seal) driver kit that ECGS offers on their website, I recommend using a small pipe to slide over the handle and extend the length of the tool past the knuckle so you can swing the hammer a little easier, otherwise you tend to tap on the thing for a good while before you get it started...
    After a few good whacks, it gets started and you drive it in until is is just flush with the champhered edge of the bearing race in the diff housing. Then replace the seal (if needed) and reinstall your axle as norm.
    On the test drive, the growling and the vibration felt in the floor was gone, and the truck was noticeably quieter going down the road. I put the truck in 4wd, for a bit to circulate the gear lube in the diff and then shut it off. There was no "growl-off, growl-on" indication as before when you put it into and out of 4WD.
    I will chime in at a later date if there are any other issues... for now, I think this bushing repair is the cure for the dreaded "lifted tacoma growl"...
    (Props to ECGS for putting this kit together!!)
    birry likes this.
  7. Feb 18, 2014 at 6:11 AM
    #147
    ksmoove757
    Kenneth
    VA BEACH
    So what is the exact problem with the growling? Is the oem bushing broken in there, causing the growling sound? I'm just just trying to figure out the mechanics behind it. The noise is starting to really annoy me.
  8. Feb 18, 2014 at 6:38 AM
    #148
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    ^ To sum it up...too much slop and carrying too much of a load (weight of CV Axle).
  9. Feb 18, 2014 at 8:24 AM
    #149
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    There is no OEM bushing. It's a needle bearing and what 05Moose stated that is causing the problem.
  10. Feb 19, 2014 at 8:00 PM
    #150
    g34rh34d
    Colorado
    So Ill try to explain as simply as possible.. when you lift the truck you increase the load on the bearing and side gear due to the increased CV angles. According to ECGS; Since Toyota used a cast carrier housing, and didn't machine the surface with closer tolerances for the side gear you get an increased load on the needle bearing causing the growl. (see their you tube video here)
    The removal and replacement of the needle bearing with the ECGS bushing kit tightens the tolerance in this location and adds additional support due to the additional width of the bushing taking the load off the side gear.
    I have tried to illustrate the point (as best as possible with powerpoint...) in the attached picture.
    Hope that helps
    birry, kryten and jmdaniel like this.
  11. Feb 20, 2014 at 6:02 AM
    #151
    ksmoove757
    Kenneth
    VA BEACH
    THANKS FOR THE INFO!!!
  12. Feb 21, 2014 at 8:00 AM
    #152
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  13. Apr 8, 2014 at 4:20 AM
    #153
    skycruiser
    skycruiser Member
    Central Fl
    08 4x4 Tacoma
    Does anyone have the ECGS bushing puller I can borrow or rent?
  14. Apr 8, 2014 at 5:56 AM
    #154
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Toyota does not repair big stuff under warranty they replace them the old one goes back is overhauled and becomes a replacement for the next one. If you feel a roughness and have a grinding type of noise at low speeds that goes away in 4WD it is the needle bearing axle support. Toyota replaced the front diff in mine for the very same reason. The ECGS replacement is exactly like the old GM X body cars that had similar issues with their front drive transmissions.
  15. Jun 12, 2015 at 4:20 PM
    #155
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    So is this bearing only on the drivers side. Is there something on the passengers side that could cause the growling?
  16. Jun 13, 2015 at 4:22 AM
    #156
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Both have a bearing but different design. No doubt this will start some thing but this is why Toyota says to drive the truck in 4WD 10 miles or more per month. When it is not in 4WD only the axles spin the ring gear doesn't and the oil does not get flung around inside of the diff to lube the bearing at either end. This design came from GM and frankly it should have stayed there I had no problem locking in my front hubs and in the winter just left them locked in worked for me for over 285K miles.
  17. Jun 13, 2015 at 5:27 AM
    #157
    Pigpen
    Dan
    Northwest Montana
    I miss locking front hubs...
    I use 4wd much more than recommended and still had to replace the bearing. The noise started at 45k (when I lifted 2.5"). I had the bushing installed at 55k a couple weeks ago and the bearing looked fine, and my mechanic said there was zero damage to the axle - yet.
  18. Jun 13, 2015 at 1:23 PM
    #158
    GTABurnout
    Tucson AZ
    has any one replaced the bearing with a new oem bearing? There only $12....
  19. Jun 13, 2015 at 4:33 PM
    #159
    05Moose
    Jim
    I did about 8 months before ECGS had made their bearing. Still working fine after 50k miles with 5100s set to 1.75. But I wouldn't waste my time taking it all apart only to throw in another poorly designed part knowing in the future it will go bad. When this 3rd one fails (yes, 3rd!), ECGS bushing it will be.
  20. Sep 25, 2015 at 4:45 PM
    #160
    Toeb
    Toeb Well-Known Member
    Toby
    Nc
    Trd off road
    Spc uca and leveling kit, 17" drop star 645 265/70/17, n fab step rails.
    I'm gonna rehash this once again. Here's my issue and what's been replaced so far. Growling noise between 25-40 mph happens in drive and neutral and 2wd or 4 wd makes no difference sounds like it's coming from the passenger front side. I have replaced upper and lower ball joints cv axles both front wheel bearings twice second set came from bamatoy. I've done the ecgs bushing changed all diff and transfer case fluid have all new u joints and carrier bearing. I'm at a total loss on what it could be! Truck runs smooth there's no vibes at all just the noise. It doesn't change sound when weaving left to right either like a wheel bearing would. Any advice at this point would be a blessing. Thanks
    lonewolf1911 likes this.
