Front end lift questions...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Oct 2, 2010.
  1. Oct 2, 2010 at 5:40 AM
    Larry
    Larry [OP] CARL
    CARL
    OK...so I got the rear springs TSB done...and it lifted the rear 1-1/2".
    I'm happy with the ride and the look...I had it done mostly for hauling and towing.
    Now I'd like to lift the front about one inch to level out the truck a little.
    I also plan on replacing the 245 tires with 265 tires. Speaking of tires...do I get the front end lift work done 1st, w/ alignment?...or get the tires installed then do the front end work and an alignment?
    What is the best way to achieve the small front end lift? Bilstein 5100's? Or new coils? Other? I want to do it economically, but I don't want to screw with the ride or factory engineering too much.
    Not a fan of shims...although I'd like those with the 1/4" "Taco Lean" shim to comment, this is something I'd be interested in doing when I make the subtle front end mods.
    Lots of questions...thanks for any imput you can add...
  2. Oct 2, 2010 at 5:57 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Cheapest route would be some adjustable front Bilstein shocks. Avoid spacers due to ride quality. I would get the tires,front end, and alignment done at the same time. You changing the tires and front end separately may change your alignment specs.
  3. Oct 2, 2010 at 11:27 AM
    Larry
    Larry [OP] CARL
    CARL
    So...the 5100's are less cost than a set of coils? I would think the coils would be less? And if I changed coil springs...would the stock shocks be OK?
    and, any feed back on the "taco-lean" shims? worth the trouble? waste of time? negative ride effect?
  4. Oct 2, 2010 at 11:44 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    a pair of front Billies would be around $160. Not familiar with the shims or coils you are interested in. I have coilovers which are coils/shock combo. Much more costly. Toytec coilovers are about $800. The think the Billies 5100 are adjustable up to 2.5". I would think you will need longer shocks for coil springs lift.
  5. Oct 2, 2010 at 1:33 PM
    Larry
    Larry [OP] CARL
    CARL
    thanks...I'm only looking to pickup about one inch of front lift.
  6. Oct 2, 2010 at 1:39 PM
    lynyrd3
    Bill
    East Central Upstate NY
    My billies are being installed at the dealer this week @ 1.75 " . Had the TSB done a few months ago . I also will be going from 245s to 265s when the rubber runs out in another month or so. I think this is the way to go since it will not stress out the front end parts too much. Researched this info a lot right here @ TW . Will get the alignment with the billies ,hope to not need another after bigger tires. If I do I will just get it done again at the dealer and hopefully they wont charge me twice .
  7. Oct 2, 2010 at 1:43 PM
    Larry
    Larry [OP] CARL
    CARL
    I believe the Billy's at 1.75 will leave my rear end low. I have 1.5 inches of lift in the rear from the TSB...
    one inch of front lift will be perfect (for me)...that way when I tow or haul with the truck...I still have some rear spring left for a level ride.
  8. Oct 5, 2010 at 12:03 PM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    unfortunately, i joined this forum after i put 2.5" spacers on my 04. Hate them. i want to fit 285/75/16 no problem. i am willing to save money and buy toytec 3.5" coilovers. is that the best route? thanks.
  9. Oct 5, 2010 at 12:31 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Go here and click on Center Picture
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
    Bilstein 5100 Series adjustments are: 0.85" / 1.75" / 2.50"
    I got the Leaf TSB and increased rear height 1"+
    With my Cap @ 200lb +/- and Bed Mat @ 25lb+ I'm still 2" higher in the rear
    I've been considering the 5100's but..........
    I'm thinking I'd rather ride high in the back with existing load,
    than ride low in the back with an additional 500lb or towing a trailer
    I'd look like a Ranger or an S-10 :eek:
    Also considering the shims for the "lean"
    CC
  10. Oct 5, 2010 at 12:40 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just get some 5100's with Eibach or OME coils i have the Eibachs and they gave me 3 1/4" from stock at half the cost of the Toytec coil-overs. The only difference is the Toytec's are adjustable wile on the truck and they look cooler.
  11. Oct 5, 2010 at 12:59 PM
    Cape Codder
    Jack
    Adjustable on the Truck? I've gotta pay more attention!
    That would negate my previous post.
    TW gonna cost me mo' money.
  12. Oct 5, 2010 at 1:04 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I did the exact same thing now im saving for some OME's
  13. Oct 5, 2010 at 1:29 PM
    lynyrd3
    Bill
    Just picked up truck from dealer , installed front Bilsteins @ 1.75 and alignment......Spanked me for $356 ! 4hr. labor and $79 alignment. Sucks when you dont have time to shop around for prices . It does look bad ass though ! New rubber in a couple weeks,from 245/75 16 to 265/75 16s. Thinking Cooper Discoverer ATR .
  14. Oct 5, 2010 at 1:33 PM
    JLee
    Jerry
    Benicia, CA
    Yeah they have a spinner wrench so that you can adjust them on the truck
  15. Oct 5, 2010 at 1:59 PM
    Cape Codder
    Jack
    thanks for the link and info
    Adjustable....only way to go
    had no intention of touching the suspension
    Research and decisions
    Damn TacomaWorld :mad:
  16. Oct 5, 2010 at 2:38 PM
    JLee
    Jerry
    Benicia, CA
    No problem and tell me about it this site is keeping my wallet empty but my truck gets better and better every week.:D
  17. Oct 5, 2010 at 2:39 PM
    Larry
    Larry [OP] CARL
    CARL
    pics plz
  18. Oct 6, 2010 at 2:07 PM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    aren't the 5100s adjustable too? and can i put the 5100s up there at like 1" and leave the spacers?
  19. Oct 6, 2010 at 2:13 PM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    i got another question for ya. can i use the orginal coil springs with the 5100s if i just set them at 1"? i just wana jack the truck up enough so i can fit 285/75/16. the cheapest way possible since i already spent time and money on the spacers. but will the 5100s work with rough country spacers? thanks a lot.
  20. Oct 6, 2010 at 2:40 PM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    4 hours for the front shocks and an alignment?? My old 03 had the front brakes done (pads, calipers, rotors), inner tie rod replaced, new muffler and tailpipe installed, and freed seized rear brake pivots done in 7-8 hours. That was last month before I sold it. I think your garage needs a coffee brewer or something!
    Tomorrow I am getting the 5100's installed at 2.5", my truck has the 4-leaf pack already so I am adding Ride Rite airbags @ 10-12 psi to keep the truck level, and a Toytec FDD kit. I have Grabber AT2 tires on 18" Monster rims to go on too. Tire size 265/70r18 = 32.6". I'll be getting an alignment done shortly after. Fingers crossed I don't get vibes :pray:
    Either way, to the OP...I'd go with the 5100's @ .85. If you go 1.75, it may be too high in the front, only by a slight amount. Any weight in the back will definitely make the truck look saggy. This is from what I understand anyway.
    I have a question though. For the winter months, I have 16" steels and 245/75r16 winter tires. Do I need an alignment when swapping rims/tires? I never did on my old 03...swapped between 225's on 15's and 265's on 16's. No lift.
