Front end rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lukin, May 16, 2011.
  1. May 16, 2011 at 3:48 AM
    Lukin
    Lukin [OP] Active Member
    New Jersey
    2011 DC TRD Sport
    Hello all. I have a 2011 dc that has developed a rattle in the front end over bumps. Seems to go away when I hit the brakes. I checked the clips on the calibers and they seem to be installed correctly. I am going to bring it back to the dealer, only had it for about a month, but I usually like to diagnose the problem before I go there so there is no bs with the service guys saying they don't hear it or can't find it. Any ideas?
  2. May 16, 2011 at 4:50 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    I had a front end rattle that happened every so often and after poking around a bit, I discovered it was the tire balancing weight. I jammed some thin foam behind it and the rattle was gone. It's something easy to check and don't forget to look on both sides of the tires.
  3. May 16, 2011 at 5:07 AM
    Lukin
    New Jersey
    2011 DC TRD Sport
    I'll check that. Thanks
  4. May 17, 2011 at 2:39 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    If you see a snake rattle sticking out of the grill DO NOT OPEN THE HOOD![​IMG]
