Front end recovery points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kai38`, Sep 16, 2012.
  1. Sep 16, 2012 at 1:38 PM
    kai38`
    kai38` [OP] Well-Known Member
    I'm looking to get a 2011-2012 4dr 4x4 Tacoma soon.
    This will be my 4th Toyota build, FJ60-FZJ80- FJ Cruiser I added front bumpers on these and had recovery points for shackles.
    This build I'm wanting to keep simple and not add a extra $700.00+ bumper just for recovery points & a place to mount lights.
    What's everyone using that's running a factory bumper? I haven't had a look up under the bumpers yet to even know whats up under there.
    Thanks, Kirk
    Anyone want to buy a '07 FJ Cruiser?
    https://skydrive.live.com/?cid=DE2D30B8B02FBAEE
  2. Sep 16, 2012 at 1:43 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    (Pictures from Google Images)
    This is the recovery hook on the passenger side.
    And the recovery point on the driver's side. (in this picture, there is an aftermarket skid, but the u-shaped thing in the top left is stock.)
  3. Sep 16, 2012 at 1:54 PM
    Ben83
    Ben83 I am faster than 80% of all snakes.
    Ben
    Central Virginia
    12 MGM TRD Sport DCSB
    Extang Solid Fold Seat Covers Trimmed the mudflaps. Husky Liners
    The TRD Sport models do not come with the tow hook installed. Only the Off-Roads get it stock. Not sure if you already had made up your mind on what trim level you are getting but wanted to give you a heads up.
    Codyfish likes this.
  4. Sep 16, 2012 at 1:57 PM
    kai38`
    Thanks, looks like the FJ under there.
  5. Sep 16, 2012 at 2:01 PM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    and this is not officially a recovery point. that's the tie down loop for the trip across the pond. Some folks have hooked to it without issue, but its not officially endorsed.
    and the TRD Sport still has an eyelet on the passenger side, its just not quite the same as the TRD Off-Road hook.
  6. Sep 16, 2012 at 2:03 PM
    bigboxyota
    bigboxyota usually lost
    make a left, first pond on the right
    Stock SR5 DCLB
    box stock
    Does Toyota list the strength or pull rating on either of those attachment points? I always thought those were merely tie-down points the workers use when the vehicle is being transported and not frame-strength recovery points.
    Am I wrong again? :D
  7. Sep 16, 2012 at 2:08 PM
    kai38`
    I think all Toyotas I've owned have had this loop, I also have been told its a tie down point for the vehicles and not really the best spot for a recovery.
    I have used it before and it's worked but there are a lot of things that can go wrong if if fails under a hard pull.
  8. Sep 16, 2012 at 2:22 PM
    Ben83
    Ben
    Central Virginia
    From what I remember reading the eyelet that the TRD Sport has on the passenger side is not meant for recovery. It is a tie down that they use during transport. Which makes sense when you look at it, because it definitely doesn't look like it was designed to be yanked on too much.
  9. Sep 16, 2012 at 3:56 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    as far as strength goes, i used both the recovery hook and the tie down for multiple nasty recoveries on the old yota. the worst was like an 80 deg (sideways) pull and hub-deep in mud. it just bent the bolts a bit. the points on this truck look to be of similar quality.
  10. Sep 16, 2012 at 4:07 PM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    I Would like to put actual hooks or something there as i dont think i will be putting a bumper on my 12' and i have not been able to find anything that i could hook up there to use. would be nice to know if there was such a recovery point.
  11. Sep 16, 2012 at 4:22 PM
    Ben83
    Ben
    Central Virginia
    This is the thread I was referencing: http://www.tacomaworld.com/forum/off-roading-trails/138114-front-recovery-points.html
    I went ahead and bought the tow hook that comes on the Off-Road for my Sport. If I am getting pulled out I don't want to have to worry about the tie-down or the eyelet becoming a metal missile that could possibly hurt a person or a vehicle.
    WheelinJ91, the part numbers for the tow hook and the hardware to install it are in that thread I posted the link to.
  12. Sep 16, 2012 at 5:27 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Hmm good to know, I'm still deciding if i want a full front bumper or not. it will depend on if i buy a pre 1990 4runner and turn it into a offroad rig.
  13. Sep 16, 2012 at 5:38 PM
    Ben83
    Ben
    Central Virginia
    This is the route I would go. If I were still in the military I would buy an older 4runner, tacoma or yota pickup to build into a trail rig. But me and the wifey are in college now so I have $0 for anything like that. Maybe someday... :D
  14. Sep 16, 2012 at 5:51 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Yeah i really want to keep my 12' simple, it is getting a lift and will be putting better tires come spring to get the dirt bike deeper into the bush before i have to unload. And i think i have a sweet line on a 1988 4runner would need a little work but then it could be a slow build.
