Front end suspension making odd sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by UtahTacoma02, Nov 25, 2015.
  1. Nov 25, 2015 at 9:05 PM
    UtahTacoma02
    UtahTacoma02 [OP] Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    Need help diagnosing a thuds and pop sounds in my suspension. It is very noticeable when it has rained and everything is wet for some reason. When I make hard turns or even slowly roll over a ditch something with my suspension or around it makes a pop sound. I have OME suspension front and back but the front is what mainly makes the noise. I am not running a sway bar was wondering if that was making the frame flex causing the popping sound. I have been under my truck several times to try and see anything out of the ordinary but still nothing. Anyone else had a similar problem or can direct me where to possibly look next. Sorry this is so vague.
  2. Nov 25, 2015 at 9:54 PM
    UtahTacoma02
    Dave
    SLC
