front end suspension rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, May 25, 2012.
  1. May 25, 2012 at 4:28 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    HI all I have a 2012 DCSB TRD 4x4. everything is solid with one exception. When I hit sharp bumps like a pothole I get a slight rattle from the front suspension. Its almost like a jingling noise. Nothing too bad, most bumps there's no noise, just when I hit larger sharp bumps.
    Do you guys think there's something wrong? I'm taking it in soon for the 5K service so I want to be prepared. Or should I even mention it?
    Thanks!
  2. May 25, 2012 at 4:40 PM
    forana
    Kaneohe, Hawaii
    bone stock. Could be the pad rattling now that you mention it. I wouldn't expect a new truck's pad to rattle thought but its a possibility.
    Its really hard to recreate the noise because its only rattles when I hit hard bumps which is rare.
  3. May 25, 2012 at 5:43 PM
    forana
    Kaneohe, Hawaii
    thanks wolf, I had an old toy truck that had rattling brake pads. THis sound is very similar the more I think about it.
    Thanks for the info!
  4. May 25, 2012 at 6:30 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    There is also a tsb issued for the intermediate steering shaft clunking and rattling over rough and bumpy roads. Not sure if this issue was addressed in 2012 models but I have an 09 and they did the tab for me. Turns out that wasn't even what was wrong but regardless I have the new steering shaft now. Its supposedly tighter (less front end play) during bumpy driving conditions also which is noticeable IMO. I know there is some type of zip tie mod/fix to address this issue that is very simple. I didn't find out until after my tsb was already completed but you may want to try that first see if it fixes it. Sounds like this could be more likely what your describing. I'm sure another member can explain the zip tie fix cause I really don't know much about it since it didn't affect me. I've heard it works great though and actually lasts too :)
  5. May 25, 2012 at 9:16 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    06 DCSB with 98k and I have never heard the pads rattle or what ever they call it, which would be a dull sound because of the pad lining not the jingling type sound you describe
    my suggestion would be to jack up the front or put on lift and smack the tire with a BFH at the 6 or 7 o'clock poss. too repilcate a sharp bump and see what you find
    just my 0.02
  6. May 25, 2012 at 10:34 PM
    DATZ WEAKSAUCE
    DATZ WEAKSAUCE Well-Known Member
    San Jose, CA
    17 DCLB TRD OFF ROAD LT PROJECT
    mention it and tell the advisor you'd like to go on a road test with the shop foreman so you can show him the noise and it will get resolved if its an abnormal noise :thumbsup:
  7. May 27, 2012 at 5:48 AM
    tpr676
    tpr676 Well-Known Member
    My 12 sport short bed has 3,000 miles on it it started to rattle sounds like a aluminum ladder on a pick up truck rack. It should be tight as a ducks ass for a 35 thousand dollar truck with 3 grand on the clock. Thank god I have the extended warranty I got a bad feeling I will need it.
  8. May 27, 2012 at 6:13 AM
    mdkingen
    mdkingen Hang on, I saw this done in a cartoon once!
    Las Vegas
    2012 Tacoma
    I have a 2012 reg. cab that I just recently put an O.M.E. 3" lift on. Now when I shift gears, as I depress the clutch and the rpm's start to drop as I move the stick between gears I hear a rattle coming from the front of the truck. I can't feel a vibration but there is a definite rattle. I have looked everywhere. Any ideas?
  9. Jun 14, 2012 at 9:07 PM
    Drabbit17
    Drabbit17 Active Member
    Diego
    Costa rica
    05 sr5 access cab
    did you find the problem. I think my car has the same sound.. and I havent been able to get to the problem.
