Front End Vibration/Humming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by birry, Jul 15, 2013.
  1. Jul 15, 2013 at 3:29 PM
    birry
    birry [OP] Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I have a 2008 V6 4x4 DC that's started making this humming/groaning/vibration sound and it sounds like its coming from the front driver's side wheel. I thought it was just engine or road noise at first, but I've identified a unique sound and it seems to be getting worse.
    Some characteristics to help diagnose the issue.
    --It varies directly with vehicle speed, and sounds the worst between 30-50 mph.
    --The sound/vibration actually goes away completely when turning to the right, but it does not go away when turning left.
    --It is definitely coming from that particular area. It doesn't sound like its near the middle of the truck, which could mean a differential or something.
    Any ideas? If it is a wheel bearing, is that a relatively easy DIY for a slightly mechanically inclined individual??? thanks for the help!
  2. Jul 15, 2013 at 3:34 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
  3. Jul 15, 2013 at 3:46 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
  4. Jul 15, 2013 at 5:44 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I'm having the exact same issue to a T! I believe it's a wheel bearing but I'll be watching your thread to see what you determine. And let you know if I get mine solved in the meantime
  5. Jul 15, 2013 at 6:16 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Cool. Glad to know I'm not the only one. Well...kinda glad. I still hope its something relatively easy/cheap to fix. I'll let you know if I figure out the problem. I'm going to do some reading on what parts I need to order and the process to change it and see if I can do it myself.
  6. Jul 15, 2013 at 7:05 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I just got home and lifted the front of my truck and sure as shit I have quite a bit of play in the drivers side bearing, passenger side was still firm. No doubt now it's the bearing. I guess my Saturday is now planned, unless I decide to drop the coin on a shop repair(as I don't own a press)...depends on cost, I'll call tomorrow. Good luck to you
  7. Jul 16, 2013 at 4:08 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Good to know! Thanks for the info. I'm not sure what tools are required to do the job.
  8. Jul 16, 2013 at 7:13 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Tried it this morning. It still makes the noise even in 4HI. I've found that its really loud when I coast from about 40mph down to about 10mph. Gotta be a wheel bearing.
  9. Jul 16, 2013 at 7:16 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Definitely wheel bearing, and yes, you'll need a shop press to swap out the bearings.
  10. Jul 16, 2013 at 7:24 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Is that the only part that isn't a relatively easy DIY?
  11. Jul 20, 2013 at 8:23 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    New bearing going on today! I'm hoping all goes well on the removal and installation...I can't wait for the smoother ride back.
    Did you solve yours or identify it as a bearing yet?
  12. Jul 20, 2013 at 8:06 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Replaced both front wheel bearings, all went smooth and fixed the issues completely
  13. Jul 20, 2013 at 8:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thanks for the heads up. Next.
  14. Jul 21, 2013 at 4:56 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Great to know! I've had fires to put out on other vehicles (not literally), but the wheel bearing is next in line. Great to know it fixed the issue!
    I also found a couple local shops that can do the pressing. Do you need a press to remove them or just to put them back on?
  15. Jul 21, 2013 at 8:44 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Remove hub and bearing assembly as one unit, then take it to take it to have it disassembled and assembled.
    You can do it with basic hand tools, an impact, and BFH! You'll need a 35mmsocket if your trucks a Gen 2 4x4(thanks to members in attached).
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/286718-socket-size-help-please.html#post7172020
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/286568-help-wheel-bearing-part-help-needed.html
    Good luck!
  16. Jul 21, 2013 at 1:11 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Thanks again for all the info! I'm probably going to order the parts this week. I think I'm just going to order one side. Do I need to the bearing only or are there seals, bushings, or other parts that come in a kit that I'll need?
  17. Jul 27, 2013 at 12:19 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Did you order the bearing only or the entire unit?
    I'm seeing this: http://www.oreillyauto.com/site/c/d...k=Search_C0055_1441490_177&pt=C0055&ppt=C0337
    And this: http://www.autopartswarehouse.com/s...000001.html?loc=Front&tlc=Engine+&+Drivetrain
  18. Jul 28, 2013 at 11:17 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I actually spent the extra $ and got this:
    http://bluepitbearings.com/buy-toyota-tundra-complete-wheel-bearings.html
    Now I have a spare assembly to have bearings pressed at my convenience for next time. And it made changing extremely simple. I know a lot of guys would say it’s a waste of $, but it’s still cheaper than paying a shop to do the job!
    Or try this: http://www.tacomaworld.com/forum/2n...s-4x4-sale-complete-best-price-ever-save.html
    Which wasn't available when I bought mine
  19. Jul 29, 2013 at 5:24 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Gotcha. I was thinking about just getting the bearing, since I'm actually planning to sell/trade the truck once I get this repair done. If I was gonna keep it, I might invest a little extra so I could have the spare parts.
  20. Jul 31, 2013 at 10:23 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I'm ordering my wheel bearing today. I'll let you know what the result is.
