Front end whine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Super Werty, Dec 28, 2010.
  1. Dec 28, 2010 at 8:48 PM
    Super Werty
    Super Werty [OP] Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Ok I have done a TON of searching on this forum and google and havent found anybody with the same issue.
    Within the last month or so I have noticed a strange humming noise coming from the front end of my truck.
    It starts at 30mph and goes up to about 60mph, in any gear. Im positive its not the trans, as it is speed specific and not rpm specific.
    Happens when Im accelerating, braking, and coasting without braking.
    Does it in 2wd and 4wd.
    It is not rhythmic at all. It's a constant sound
    I drained the trans fluid...perfectly clean and bright red.
    I drained the front diff fluid...perfectly clean again.
    I regularly grease all the zerks.
    I then tried to check to see if the wheel bearings were good. Lifted the front and spun the front wheels by hand, and it sounds normal. No humming at all.
    Then I realized maybe its my slotted disc rotors in the front (installed july 2010), but how can I verify this?
    99% of the time I drive I have the stereo on and it drowns out all noises. So I really dont know how long this has been going on.
    Any ideas or anyone have tis same problem. I would greatly appreciate help with this. Not sure where I should start looking.
    Sounds like this....
    http://www.youtube.com/watch?v=T0q8AcMBn-w
  2. Dec 29, 2010 at 6:44 AM
    10silvertaco
    10silvertaco Well-Known Member
    Brent
    no longer own Tacoma, now own 2011 Outback
  3. Dec 29, 2010 at 7:30 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Does it sound like you're driving on mud terrains?
  4. Dec 29, 2010 at 7:44 AM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    yes. But its like I have normal tires from 0-30mph:p
  5. Dec 29, 2010 at 2:24 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Same here. It happened a week after I changed my spark plugs and rear diff fluid. Dawilldabeast rode in my truck to listen to it as well, but he said it's coming from the center of the truck. It stays with the speed of my truck. If I slow down or speed up. Doesn't follow my engine. Could be the drive shaft?
  6. Dec 29, 2010 at 3:10 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    I really dont know, but its starting to drive me nuts. I dont want to be driving down the road and have something major break.
    I ran a 12.93 with this noise:p So maybe Ill be fine, but Id rather know how to make it stop!;)
  7. Dec 29, 2010 at 3:29 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Nice! Are you in the high 300s?
  8. Dec 29, 2010 at 3:31 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    My old 06 had a whine. it was the PS Pump.
  9. Dec 30, 2010 at 11:33 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    I think it is the PS pump... It stops when I'm holding a turn. And I have noticed some PS fluid leaked out about 4-5 months ago. New pump?
  10. Dec 31, 2010 at 8:59 AM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    Hmm, Ill have to try that. I doubt it though
  11. Dec 31, 2010 at 11:50 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Subscribed
  12. Mar 8, 2011 at 8:53 PM
    Sum1Else
    Sum1Else Member
    San Diego, Cali
    07 4x4 Sport
    Super Werty, or anyone else, I'm sure you have found the cause for this by now, any suggestions?
