Front Frame thingy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jkuniverse, Jan 20, 2020.
  1. Jan 20, 2020 at 3:41 PM
    jkuniverse
    jkuniverse [OP] Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Can this piece be removed? It looks like a cap or extension. Wonder if removing it will alter the integrity (safety) of the frame. I’m thinking about mounting a set of driving/fog lights.
  2. Jan 20, 2020 at 3:43 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    When I installed my ARB bumper, the instructions said to remove those so bolts could be placed there. I don’t know what their purpose is...
    llamasmurf and jkuniverse[OP] like this.
  3. Jan 20, 2020 at 3:43 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yes, you can remove it. The bolt on the bottom holds it in.
    SR-71A and jkuniverse[OP] like this.
  4. Jan 20, 2020 at 3:49 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  5. Jan 20, 2020 at 4:14 PM
    pdaddy
    Preston
    Central AL
    So if it can be removed, what exactly is the purpose of this extension thing?
  6. Jan 20, 2020 at 4:41 PM
    Muddinfun
    Muddinfun Well-Known Member
    Nobody knows for sure, but it has been speculated that the truck failed the offset head on crash test by this >< much, so they added that doohickey and passed.
  7. Jan 20, 2020 at 5:48 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Must be nice to drive in a salt free area. The undercarriage looks almost new.
  8. Jan 20, 2020 at 6:14 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    If you used proper undercoating on a regular basis, yours could be nice as well.
    o_O
  9. Jan 21, 2020 at 9:25 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Not to derail thread, but on my 2009 those ends are starting to have surface rust...should they be removed if so?
    My frame looks pretty good otherwise...thankfully not too much salt/brine used here in NC.
    Thanks.
  10. Jan 21, 2020 at 3:41 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    36,000 yield strength 6061 aluminum, 1.0 inches thick
    Marc70 likes this.
  11. Jan 21, 2020 at 4:28 PM
    pdaddy
    Preston
    Central AL
    Still not sure what it really does but that’s a nice subtle touch
  12. Jan 21, 2020 at 5:05 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    Provides two anchors for 3/4 shackles.
  13. Jan 21, 2020 at 5:08 PM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    Only as strong as what its attached to. That 36000lbs means little in this application
  14. Jan 21, 2020 at 5:08 PM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    yikes! those points are not strong enough for a 3/4 shackle
    ajmogen likes this.
  15. Jan 21, 2020 at 5:11 PM
    kystnTRD
    NW Pennsylvania
    2016 TRD Sport 6MT
    That spot is not rated for a 3/4 shackle
    ajmogen likes this.
  16. Jan 21, 2020 at 7:11 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    All of these attachment points are only as strong as the sheet metal they are attached to. Factory parts included. The 6061-T3 aluminum is the same same strength as mild steel ASTM A-36 ( also 36,000 yield. There is roughly 2.0 inches of metal in the eyelet - so 36 Tons at pull out of the eye - just about equals destruction of a common 3/4 shackle with a 7/8 pin. The point is ........ None of this stuff will fail before you damage the truck frame.
    DG92071 likes this.
  17. Jan 21, 2020 at 7:15 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I really didn’t see the point to it
    Sterling_vH111 likes this.
  18. Jan 21, 2020 at 7:21 PM
    kystnTRD
    NW Pennsylvania
    2016 TRD Sport 6MT
    My point exactly, it's a recipe for failure, in this case at the expense of your truck. Shackles are not to be rated at their destructive strength, they have a 5:1 safety factor for a reason. Point is, dont attach a shackle of any rating to something of a lesser rating. I work with rigging everyday as an ironworker by profession, this is how people get hurt or killed.
    VanDoom likes this.
  19. Jan 21, 2020 at 8:09 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I think it’s probably to help (a little?) with impacts coming at that angle. Like when they show the crash tests from a car hitting a corner.
  20. Jan 21, 2020 at 8:10 PM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    I fail to see the logic of your reply - if the eyelet won't pull out - right up to the destruction limit of the 3/4 shackle, then the rigging is properly matched. Period. If a force is then applied in excess of the structural limits of the truck - that is entirely up to whomever applies the force. But it won't go flying. I too have been making big lifts - for forty years - and rigging match or overkill is always a good idea when it's easily applied. That is why some huge number of these trucks have one or more of the 3/4 shackles hanging off of them. That is how you try to keep people from being hurt out of ignorance.
    My pull ring on the rear hitch is constructed for a 1.0 shackle and sometimes I hang one on there just to scare Prius drivers in the parking lot.
