Front growling after 2" lift
Discussion in 'Suspension' started by 916 YATES, Apr 26, 2013.
  1. Apr 26, 2013 at 7:48 AM
    916 YATES
    916 YATES [OP] Well-Known Member
    Brian
    Sacramento
    2010 DCLB Grey TRD Sport
    emblems and decals removed, added TRD special edition badges, Sway A Way's front and rear, SCS stealth 6's, Toyo A/T II 265/70/17
    front growling after lift
    [​IMG]Lifted approx 2" front is now growling. Is it just my CV's not happy anymore. Checked for anything rubbing like dust sheild backing plates. Did coil overs only. No drop kit. alignment is in specs. Tires and wheels still stockers.
  2. Apr 26, 2013 at 7:52 AM
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
  3. Apr 26, 2013 at 8:11 AM
    916 YATES
    Brian
    Sacramento
    put in 4 HI, went away completely, even back in 2 Hi. thanks
  4. Apr 26, 2013 at 8:13 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Hang on
    If you put it in 4HI and the noise goes away , you need the bushing , at least that's how it reads to me
  5. Apr 26, 2013 at 8:17 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    fixed... Said do instead of don't
