Front higher than rear - OME 3" Suspension
Discussion in 'Suspension' started by JGJ, Sep 20, 2010.
  1. Sep 20, 2010 at 5:34 AM
    JGJ
    JGJ [OP] Well-Known Member
    I just installed the full 3" OME Suspension lift last week.
    The front sits a bit higher than the rear - which I don't really like.
    To get it where I like it I would need another 1/2" on the rear.
    Any suggestions of the easiest way to achieve this without going too high in the back?
    Thanks
  2. Sep 20, 2010 at 5:37 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    the front might settle im not sure, but you can put a small lift block back there
  3. Sep 20, 2010 at 5:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 on letting it settle.
    What springs did you use?
  4. Sep 20, 2010 at 5:56 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    Add the D29XL add-a-leaf in the back...it puts the rear at the perfect height for the full 3" front setup. You will be left with about 1" of rake. ...my two cents.
  5. Sep 20, 2010 at 10:50 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, different resellers have different meanings for what the "full" OME suspension consists of. Did you add any top-plate spacers?
    Which parts did you put on, and what's the configuration of your Taco? (std/access/extended, 4x4/pre runner, heavy options such as bumpers, etc...)
  6. Sep 20, 2010 at 1:29 PM
    Eesh
    Eesh Well-Known Member
    Canada
    2025 Tacoma Limited
    What kind of leaf springs do you have on the back? AAL? Dakars?
