Front IFS 7.5" E-Locker and rear 8.4" E-locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Jun 23, 2016.
  1. Jul 22, 2018 at 1:59 PM
    #221
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Meh, turn it around for a whole 'nother life
    MotoEd[QUOTED] likes this.
  2. Jul 25, 2018 at 4:36 PM
    #222
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Curious how the wiring harness is designed. Apologies if this has been asked already, I didn't read through the entire thread...
    Is it powered from the stock rear locker? In other words, do you have to be in 4Lo and have the rear locker engaged before engaging the front?
    I could see advantages to the front locker able to engage without the rear, or in 4Hi (like the grey wire mod does for 2Hi).
  3. Jul 25, 2018 at 4:46 PM
    #223
    TireFire
    Olympic Peninsula
    Simple stand alone harness. Will engage whenever you want it to (obviously shouldn't be engaged during wheel spin or high speeds)
    jbrandt[QUOTED] likes this.
  4. Jul 25, 2018 at 5:45 PM
    #224
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Nothing over 3mph
  5. Jul 25, 2018 at 6:42 PM
    #225
    TireFire
    Olympic Peninsula
    Actually my manual said 5mph but once engaged you can go as fast as you want (that's not what the manual says tho haha)
  6. Jul 25, 2018 at 6:47 PM
    #226
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    You know if that was in my truck it would be going in at about 50 right before I entered that corner on the 72 road... at the top of the switchbacks.
  7. Jul 25, 2018 at 6:51 PM
    #227
    TireFire
    Olympic Peninsula
    Squeeeeeel...
    ....BANG! Or you go flying off that cliff. Hope you brought some Redbull
  8. Jul 25, 2018 at 6:52 PM
    #228
    JimSnell
    Jim
    Puyallup
    The latter is more likely. And by red bull, did you mean beer?
  9. Jul 25, 2018 at 6:56 PM
    #229
    TireFire
    Olympic Peninsula
    As long as it gives you wings, sure
  10. Jul 26, 2018 at 8:44 AM
    #230
    smmarine
    Melbourne FL
    Mine says 5kph, which is 3mph :p
  11. Jan 18, 2020 at 9:55 PM
    #231
    03taco
    03taco Well-Known Member
    Alex
    2004 Taco
    Never Ending Project
    I recently installed the harrop e locker for the front differential, I noticed that the driver side CV axle is leaking. Did anyone have this issue, or know someone that had this issue
  12. Jan 19, 2020 at 7:26 AM
    #232
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I did not have this issue, but it sounds like a bad seal, probably unrelated to the locker. Your truck is 17 years old...Pics would help.
  13. Jan 19, 2020 at 8:42 AM
    #233
    03taco
    Alex
    2004 Taco
    Seal is brand new. I will try to get some pictures today
  14. Jan 19, 2020 at 8:52 AM
    #234
    Prayn4surf
    Socal
    Probably not seated right, or something. The locker shouldnt be the cause of forcing gear oil out.
  15. Jan 19, 2020 at 9:04 AM
    #235
    03taco
    Alex
    2004 Taco
    Alrighty thanks
    Prayn4surf likes this.
  16. Jan 19, 2020 at 10:57 AM
    #236
    03taco
    Alex
    2004 Taco
    Did you use the same seal?
  17. Jan 19, 2020 at 11:26 AM
    #237
    Prayn4surf
    Socal
    I had ecgs install mine and then just put the cv’s back in and havent had any leaks. I wish I had better info for ya. Only issue I had was toyota over filling my front diff and it barfed fluid all over my engine bay via the breather. That was fun..
  18. Jan 19, 2020 at 11:35 AM
    #238
    03taco
    Alex
    2004 Taco
    Do u have to have the ecgs ?
  19. Jan 19, 2020 at 2:24 PM
    #239
    TireFire
    Olympic Peninsula
    If you mean their bushing to replace the stock needle bearing then no. Not a must have. I still don’t have it but kept my suspension lift to a minimum just enough to clear 285 (with some cuttin and chopping )
  20. Jan 19, 2020 at 7:38 PM
    #240
    Prayn4surf
    Socal
    What @hx989 said. I do not have the bushing either. Is your leak by the driveshaft or the cv?
