front lower ball joint replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taniwha, Oct 30, 2024.
  1. Oct 30, 2024 at 9:48 AM
    Taniwha
    Taniwha [OP] Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    Looking to do the lower A-arms on my '09 4x4 Taco. Much of a savings buying ball joints and bushings as opposed to new A-arms? TIA Cheers, Dave
  2. Oct 30, 2024 at 9:53 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Recommend buying a new LCA with the ball joint installed by the vendor. Big savings in the PITA factor (IMHO).
    skee likes this.
  3. Oct 30, 2024 at 5:17 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Thanks man. Rock Auto has some. Freight to Canada will be a killer tho :-/
  4. Oct 30, 2024 at 5:32 PM
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    X2
    I recently did both LCA’s and used the ones from A1 Auto for about $190, although most will recommend going OEM. Rock auto probably has similar quality/price LCAs but OEM is pricey and I figured I could replace these 3 times before the cost evened out with what the OEM arms cost. No issues so far but only have about 1000 miles on them. I would plan on having to cut off and replace the cam bolts as well, and if you don’t end up needing to that’s a bonus. There are so really good YouTube videos from A1 auto on how to do this job if you need them.
  5. Oct 30, 2024 at 8:05 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I too replaced the LCA and UCA. People will say "Go OEM" or your truck will explode on the highway.
    Replacing the Ball itself would have been cheaper but its so labor intensive its not worth it.
    Went with CK MOOG LCA and UCA from Lordco at $300, as OEM Toyota Arms locally is very expensive at Approx $500 per arm not including labor.
    If you do go with Lordco (which is slightly more expensive than Rock Auto) make sure you give them the part number you want. They had all the parts I needed, also "upgraded?" to SPC LCA bolts while I was there.
  6. Oct 31, 2024 at 9:16 AM
    Taniwha
    Dave
    Kamloops, B.C.
    Thanks for the Intel guys. I'll check Lordco as I occasionally get a discount there. Top ones and struts are already done with OEM take offs.
