front mud flaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by regcabtaco, Dec 12, 2009.
  1. Dec 12, 2009 at 11:04 AM
    regcabtaco
    regcabtaco [OP] Well-Known Member
    idaho
    05 tacoma sr5
    I want to take off my front mud flaps but once i removed the screws i cant get the clips off without breaking them. So can someone tell me how to remove them.
  2. Dec 12, 2009 at 11:12 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2008 double cab, 4X4, V-6, TRD. Super White.
    OME 885 coils & front shocks, with TT top plate, Total Chaos UCA, Rear OME extended shocks, Rear TSB, Rear Toytec AAL, trimmed the saber-tooth-tiger-long-ass mud flaps. 17" XD Revolver rims, 265/75/17 BFG AT KO's. Ripped out the crappy FM Modulator & installed a PA-15-toy interface. OEM bed matt.
    If I remember correctly, you should be able to use a thin screwdriver to pry them out a 1/4" or so. Then use a pair of needle nose to depress the tabs & pop it out.
    You can usually reuse them 3-4 times before they break, however they can break on the first romoval.
  3. Dec 12, 2009 at 12:08 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yeah it can be a little tough if there is dirt in the clips. Just take your time with a flat screwdriver as the above poster said.
  4. Dec 12, 2009 at 1:20 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    There is a very small "gap" in the circumference of the top flat part of the rivet.
    Look for it and use a small flat head to pry it up at the gap while using fingernails on the other side to help.
  5. Dec 12, 2009 at 1:41 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I'm debating doing this as well. I may just trim them though
  6. Dec 12, 2009 at 1:48 PM
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    the pins are less than a buck so, just break them if you have too !
