front oxygen sensor removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by tiobob, Oct 18, 2011.
  1. Oct 18, 2011 at 6:14 PM
    tiobob
    tiobob [OP] New Member
    I am trying to replace the oxygen sensor on my 2001 Tacoma V6 ExtraCab,manual trans. I finally got the nuts off the front sensor, just in front of the cat. My question is how do you find the l plug above the transmision. Where is it? I removed the console to look in the shift hole but can't reach it. Help tiobob
  2. Oct 18, 2011 at 6:20 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    It was right by the sensor for me. Right under the truck. Just trace the wire to the closest connector.
    There was one write up about taking out the center counsel to get to the connector so it might be different for you.
  3. Oct 18, 2011 at 7:23 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I just replaced this on my 2001 V6 xtra cab a/t. Not sure if it makes a difference, but it is officially an Air/Fuel sensor, not an O2 sensor - but they look identical. My plug was only about 8" away from the sensor itself and very easy to access. In no way did I have to get close to going through the console. Perhaps it is different on the manual transmission equipped vehicles?
  4. Oct 18, 2011 at 7:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    It may be under the passenger side carpet.
