Front Range Offroad Rock Surfer IFS Skid Plates
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Front Range Off Road, Jul 14, 2016.
  1. Jul 14, 2016 at 7:40 AM
    Front Range Off Road [OP] Well-Known Member
    Brian
    Formula Toyota
    We're excited to release our IFS Rock Surfer skidplate set for 96-02 4Runners! We started with a basic skid, like what other offer, and quickly found we needed to add a LOT more for protection in offroad use! A Strong mounting system design was required. Radiator protection was a must, ESPECIALLY at the outer corners! Internal reinforcements to prevent collapse. Easy install as possible.
    -3/16" steel construction
    Welded corners for supreme strength and protection for that low hanging radiator
    -Unique clamp on style mounts, hardware never loosens, overtightening wont crush yours frame!
    -100% bolt-on, with provided hardware and brackets
    -Welded internal reinforcements
    -TWENTY bolts mount these skids!
    Rock Surfers IFS Skidplate Set - Front Range Off-Road Fabrication
    Available at a discount for pre-order now!!
  2. Jul 14, 2016 at 1:20 PM
    Wulf
    Wulf no brain just damage
    Kira
    1789 28th St, Boulder, CO 80301
    rock raisin
    No 1st gen Tacoma option?
  3. Jul 14, 2016 at 1:36 PM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    1st gen or GTFO
    JasonLee, DJB1, CThorz2 and 1 other person like this.
  4. Jul 17, 2016 at 11:17 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    3rd gen t4r shares the same as 1st gen tacoma.
    confirm w/ vendor but i'm 99% sure
  5. Jul 17, 2016 at 6:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    All three skid pieces for this price? Any pictures of how the belly pan attaches? It looks like it might mount to the transmission rear mount crossmember but what does the very aft end attach to? Also, how far past the t-case does it extend?
  6. Jul 19, 2016 at 6:17 AM
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    Interested if these fit first gen Taco...
    Also, when is that LT kit coming out? :spy:
    NateMob likes this.
  7. Jul 19, 2016 at 7:35 PM
    Bennett707
    Oregon
    @Front Range Off Road
    not a lot of people selling first gen skids,
    answer some questions
    get some sales
    profit
  8. Jul 20, 2016 at 6:48 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks to me like it stops at the tranny mount cross bar. No t case coverage.
    Digiratus[QUOTED] likes this.
  9. Aug 24, 2016 at 8:47 AM
    Brian
    Formula Toyota
    There is a rear crossmember added in behind the tcase, full tcase coverage at that point. This post was a little preemptive by one of the guys here, and we're close to releasing said crossmember, but theyre not done just yet!
  10. Aug 24, 2016 at 8:47 AM
    Brian
    Formula Toyota
    All 3 pieces, however the tacoma will need an additional crossmember piece (releasing shortly) to mount the final plate.
  11. Aug 24, 2016 at 3:42 PM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    If we utilize the "Pre-Order" option for the discount, will it include the unreleased/unfinished part for our 1st Gen Tacoma once it comes out?
  12. Aug 24, 2016 at 4:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^^^ what he said. Be a great setup if so
  13. Aug 24, 2016 at 8:29 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 TRD, Greenbean!, Armor, lifted, Flatty, stuff.
    Definitely interested in this...
  14. Aug 24, 2016 at 8:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    How far past the t-cast does the 3rd piece end?
  15. Jun 24, 2019 at 7:01 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Was this ever released?
  16. Jul 21, 2019 at 1:40 AM
    evil03
    evil03 Active Member
    Socal
    2000 Tacoma SR5 TRD 4X4
    Same ^^^
  17. Jul 21, 2019 at 7:02 PM
    Wulf
    Kira
    rock raisin
    OP hasn't been online in almost 2 years. Best to contact directly by phone for an answer
