Front, rear diff and T-case fluid change
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Jul 3, 2011.
  1. Jul 3, 2011 at 10:47 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    i've been searching for a "how-to" on these, and noticed it's not in the "how-to" thread
    lots of threads for 2nd gens but no 1st gens
    thanks
  2. Jul 3, 2011 at 11:23 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    same concept. crack open the filler plug (make sure your wrenching the correct bolt). remove the drain plug (again correct bolt). if you like, use a new crush washers and put drain plug back in. fill it up and put fill plug back in.
  3. Jul 4, 2011 at 8:05 AM
    vantaco
    ya i got that...i know "what" to do, was just thinking there must be a write up somewhere that should be linked in the "how-to" thread
  4. Jul 4, 2011 at 8:19 AM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
  5. Jul 4, 2011 at 5:15 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Yup,
    just drain and fill like you would with an engine. Check your owners manual for the correct fluid capacites.
  6. Jul 5, 2011 at 4:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    The "fill" part can be pretty tricky as the way everything is designed gravity works against you. I'd invest in a little pump to pump the new oil in.
  7. Jul 5, 2011 at 9:37 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    Just finished doing this so I thought I would chime in
    I did the fluid change on the transmission, transfer case, and rear differential. I would have done the front, but the drain plug was a different size than the diy write ups noted for. The fill is 10mm, but the drain plug must be 12mm or so.
    I used Redline MT 90 for the Transmission, and Redline 75W-90 for everything else. I also greased the driveshafts while I was under there.
    In hindsight, it would have been nice to get the whole truck up on jack stands.. it was pretty cramped. Maybe I need a lift kit.. lol
  8. Jul 6, 2011 at 7:30 AM
    vantaco
    can anyone else confirm the drain bolt size? i've only got up to 10mm
  9. Jul 6, 2011 at 7:36 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The front diff is a 10mm hex key.
  10. Jul 6, 2011 at 8:58 AM
    cmj
    Tucson
    98 Tacoma 4x4
    FWIW:
    Yours should be 10mm based on the model year.
