Front/Rear Differential Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jgtgc, Apr 19, 2025.
  1. Apr 19, 2025 at 2:07 PM
    jgtgc
    jgtgc [OP] New Member
    2023 TRD PRO
    Hello TacomaWorld,
    I have a 2023 TRD Pro automatic and everything is stock that just reached 30K miles. I pumped 1.6qt in the front and 4.2 qt in the rear. However I didn't have any drip out of the fill opening like many videos showed would happen, should I add more or leave as is? Any information helps just wanna make sure I'm in the clear.
    Thank you all in advance!
  2. Apr 19, 2025 at 2:11 PM
    Bishop84
    Bishop84 Well-Known Member
    It's not an exact science, no surface is 100% level nor does every diff drain at the same rate.
    You must fill it until it spills over.
    At the very least you should be able to touch the fluid with your pinky.
  3. Apr 19, 2025 at 2:13 PM
    jgtgc
    2023 TRD PRO
    Ok then I definitely will, thanks alot man!
  4. Apr 26, 2025 at 8:05 PM
    pultaco12
    pultaco12 Active Member
    2020 TRD OR 4x4 DCSB
    is this a recommended to change at 30k item?
  5. Apr 27, 2025 at 12:33 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    BlackTRD4Me likes this.
